Component: DAC Dual (MCP49x2) (Analog Output)
Revision as of 11:59, 3 February 2023 by Wiki bot (talk | contribs)
Category Analog Output
DAC Dual (MCP49x2) component
Component to drive a dual digital to analogue converter (DAC) IC from Microchip via an SPI interface. Compatible with MCP4902 (8-Bit), MCP4912 (10-Bit) and MCP4922 (12-Bit) devices.
Please click here to download the component source project: FC_Comp_Source_temp/DAC_MCP49x2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/DAC_MCP49x2.fcfx
ControlPins
ControlPins
Allows Shutdown (SHDN) and Latch (LDAC) pins to be controlled directly if enabled.
- BOOL Shutdown
0 = Shutdown Device, 1 = Device Active
- BOOL Latch
0 = Data output driven from DAC register, 1 = Data output locked
Disable
Disable
Disables the DAC output.
- BYTE Channel
0=DAC Channel 0 , 1=DAC Channel 1
Enable
Enable
Enables the DAC Output.
- BYTE Channel
Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated.
SetOutput
SetOutput
Sets the output voltage of the DAC 8-Bit: Range 0-255 10-Bit: Range 0-1023 12-Bit: Range 0-4095
- BYTE Channel
- UINT DAC_Value
The value to output to the DAC
DAC IC
Selects which DAC IC is connected and therefore the bit depth available.
Gain Option
Vref Pin Voltage
The reference voltage applied to the VREF pin.
Vref Voltage
Steps
Number of discrete output states available from the DAC.
Control Bits
Resolution
Voltage Resolution
SPI Connections
SPI Channel selector
Prescale
Prescale option selector
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Use SHDN Pin
Allows the SHDN pin to be driven from an output pin on the microcontroller. If not used then tie the SHDN pin to VCC to allow the DAC to function.
Use LDAC Pin
Allows the LDAC pin to be driven from an output pin on the microcontroller. If not used then tie the LDAC pin to GND to allow the DAC to function.
Simulate Comms
