Component: EEPROM (DS28E07) (EEPROM)
Revision as of 12:00, 3 February 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category EEPROM
EEPROM (DS28E07) component
A rugged EEPROM allowing one or more devices to be addressed and accessed. Requires a One Wire component to perform the bus operations.
Please click here to download the component source project: FC_Comp_Source_temp/EEPROM_DS28E07.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/EEPROM_DS28E07.fcfx
AddressNextDevice
Fc9-comp-macro.png AddressNextDevice
Scans for the next connected device with a matching family code. Goes through the device list generated by the ScanBus macro.
AddressSpecificDevice
Fc9-comp-macro.png AddressSpecificDevice
Starts a temperature conversion on a specific device using a hex string identifier. SerialNumber parameter should be 12 characters and contain the 48-bit Serial.
Fc9-string-icon.png - STRING SerialNumber
48-bit Serial Number e.g. "32DF4A3C1901"
GetByte
Fc9-comp-macro.png GetByte
Reads a single byte from the selected address.
Fc9-u16-icon.png - UINT Address
Address of the value to read
GetByteArray
Fc9-comp-macro.png GetByteArray
Reads an array of bytes starting from the selected address.
Starting address of the first value to read
Fc9-u8-icon.png - BYTE Data
Byte array to store incoming data
Fc9-u16-icon.png - UINT Count
Number of bytes to read from the EE memory, Range: 1 to 128 bytes
GetFloat
Fc9-comp-macro.png GetFloat
Reads a 32-bit floating point value starting from the specified byte address. For consecutive float values the address must be incremented by 4.
Fc9-s16-icon.png - INT Address
The starting byte address
Fc9-bool-icon.png - BOOL MSBFirst
0: LSB is the first byte, 1: MSB is the first byte
GetInt
Fc9-comp-macro.png GetInt
Reads a 16-bit value starting from the specified byte address. For consecutive 16-bit values the address must be incremented by 2.
GetLong
Fc9-comp-macro.png GetLong
Reads a 32-bit value starting from the specified byte address. For consecutive 32-bit values the address must be incremented by 4.
Fc9-u32-icon.png - ULONG Return
GetSerialString
Fc9-comp-macro.png GetSerialString
Gets the Serial String for the current addressed device.
GetString
Fc9-comp-macro.png GetString
Gets a string from the specified start address.
Address of the first data byte
Fc9-u8-icon.png - BYTE MaxLength
Maximum number of bytes in the string, also includes null termination byte
Fc9-comp-macro.png Initialise
Configures each matching sensor on the bus with the specified conversion bits.
SetByte
Fc9-comp-macro.png SetByte
Writes a single byte to the EE memory.
Address of the value to write
SetByteArray
Fc9-comp-macro.png SetByteArray
Writes an array of bytes to the EE memory.
Starting address of the first value to write
Fc9-u8-icon.png - BYTE Count
Number of bytes to write to the EE memory, Range: 1 to 128 bytes
SetFloat
Fc9-comp-macro.png SetFloat
Writes a 32-bit floating point value to the EE memory. For consecutive float values the address must be incremented by 4.
Floating point value to write
SetInt
Fc9-comp-macro.png SetInt
Writes a 16-bit value to the EE memory. For consecutive 16-bit values the address must be incremented by 2.
Fc9-u16-icon.png - UINT Value
16-bit value to write
SetLong
Fc9-comp-macro.png SetLong
Writes a 32-bit value to the EE memory. For consecutive 32-bit values the address must be incremented by 4.
Fc9-u32-icon.png - ULONG Value
32-bit value to write
SetString
Fc9-comp-macro.png SetString
Writes a string to the EE memory starting at the selected address. All bytes from the string will be written including the null termination.
Fc9-string-icon.png - STRING Value
Data string to write
Fc9-type-16-icon.png One Wire Component
Link to the one wire component to host the bus.
Fc9-type-21-icon.png EEPROM Size (Bytes)
Fc9-conn-icon.png Simulation
No - We use the panel GUI to perform the simulation. Yes - We use OneWire comms via an API to communicate with real hardware.
Fc9-conn-icon.png Panel Simulation
Fc9-type-16-icon.png Number EE Devices
Sens the number of sensors we can communicate with during simulation
Fc9-type-10-icon.png Serial 0
Serial number for simulated one wire device
