| Author
Matrix Ltd.
| Version
2.0
| Category
Wireless
IrDA (EB012, MCP1250, MCP2120) component
Low level routines for controlling a standard IrDA interface. Also available in the form of the EB012 IrDA E-block.
Please click here to download the component source project: FC_Comp_Source_temp/IrDA.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/IrDA.fcfx
Transmit
Basic example which repeatedly transmits a string of data via the IrDA interface.
IrDA Transmit
Receive
Basic example which waits for any incoming data and then displays the data on the LCD.
IrDA Receive
| Initialises the UART ready for IrDA data to be sent or received,
ReceiveChar
ReceiveChar
| Receives byte character from the IrDA connection.
- INT
Timeout
| Max amount of time in milliseconds to wait for data.
- INT
SendChar
SendChar
| Sends a byte character to the IrDA connection.
- INT
Char
Comms Settings
Interface
| Decides which IrDA interface IC we wish to communicate via.
Baud Options
| Baud rate option selector
Data Bits
| Number of data bits
Echo
| Echo selection
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
Use Flow Control
| Flow Control (Handshake) enable or disable. On: Two I/O pins are used to control the flow of data in and out of the device. Off: Flow control is disabled.
| Label used to help identify the component on the panel.
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data API component on the Panel.
