Component: 7Segment (Quad) (Segment)
Revision as of 12:01, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Segment
7Segment (Quad) component
14mm seven segment display. LED colour can be set from properties.
Please click here to download the component source project: FC_Comp_Source_temp/LED_7Seg_Quad.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LED_7Seg_Quad.fcfx
ShowDigit
Fc9-comp-macro.png ShowDigit
Set the number and decimal point to be displayed in the given digit of the display.
Fc9-u8-icon.png - BYTE Digit
Which of the four digits to change. (0...3)
Fc9-u8-icon.png - BYTE Value
The number value to set the digit to (0...15), 16=Clear
Fc9-u8-icon.png - BYTE DecimalPoint
Whether to show the decimal point for the chosen digit.
ShowSegments
Fc9-comp-macro.png ShowSegments
Allows the individual segments of the display to be controlled.
Fc9-u8-icon.png - BYTE Segments
8-bit Binary value to set the segments, bit0 = segA, bit1 = segB...
Fc9-type-16-icon.png Display Type
Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off
Fc9-type-16-icon.png Common Type
The state of the output common pin when the 7-segment display is active. Usually a common cathode display uses a low signal and a common anode uses a high signal. If the common pin is routed via a transistor for power amplification then the signal may need to be reversed.
Fc9-type-7-icon.png Show Seg Labels
Show segment name labels overlayed over the component.
Fc9-type-5-icon.png Common Pin 0
Pin to enable the first digit.
Fc9-type-5-icon.png Common Pin 1
Pin to enable the second digit.
Fc9-type-5-icon.png Common Pin 2
Pin to enable the third digit.
Fc9-type-5-icon.png Common Pin 3
Pin to enable the fourth digit.
Fc9-type-5-icon.png Pin0 (A)
Pin for the 'A' segments of the displays.
Fc9-type-5-icon.png Pin1 (B)
Pin for the 'B' segments of the displays.
Fc9-type-5-icon.png Pin2 (C)
Pin for the 'C' segments of the displays.
Fc9-type-5-icon.png Pin3 (D)
Pin for the 'D' segments of the displays.
Fc9-type-5-icon.png Pin4 (E)
Pin for the 'E' segments of the displays.
Fc9-type-5-icon.png Pin5 (F)
Pin for the 'F' segments of the displays.
Fc9-type-5-icon.png Pin6 (G)
Pin for the 'G' segments of the displays.
Fc9-type-5-icon.png Pin7 (DP)
Pin for the decimal points of the displays.
Fc9-conn-icon.png Colors
Fc9-type-1-icon.png LED Color
Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Fc9-type-1-icon.png Body Color
Color of the plastic casing containing the LEDs.
Fc9-type-1-icon.png Label Color
Color for the optional LED segment labels.
