Component: LED (EB004) (E-blocks 1)
Author | Matrix TSL |
Version | 1.1 |
Category | E-blocks 1 |
LED component
An LED matrix made up of standard PCB mount 5mm LEDs.
Please click here to download the component source project: FC_Comp_Source_temp/LED_Array_EB004.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LED_Array_EB004.fcfx
AllOff
AllOff |
Turns off all elements | |
Return |
AllOn
AllOn |
Turns on all elements | |
Return |
BarGraph
BarGraph |
Turns on the first N elements of the array - for generating bar graph metes etc. | |
Length |
How many items to light up. | |
Return |
LEDOff
LEDOff |
Turn off the selected led. | |
Index |
Index of the LED to turn on. | |
Return |
LEDOn
LEDOn |
Turn on the selected LED. | |
Index |
Return |
PointGraph
PointGraph |
Turns on the Indexed LED and turns all others off. Does nothing if the index is out of range. | |
Index |
The LED to show. | |
Return |
WriteValue
WriteValue |
Write a number which is presented on the LEDs in binary. | |
Value |
Provide a value to be written to the LEDs in binary | |
Return |
Properties |
Connections |
Output Mode |
Choose a single port for all LEDs, or to allocate them to arbitrary pins. | |
Port |
