Component: LED Array (PCB) ()
Revision as of 12:01, 3 February 2023 by Wiki bot (talk | contribs)
Author Matrix
Version 1.1
Category
LED Array (PCB) component
An LED matrix made up of standard PCB mount 5mm LEDs.
Please click here to download the component source project: FC_Comp_Source_temp/LED_Array_pcb.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LED_Array_pcb.fcfx
Fc9-type-21-icon.png Count
The number of LEDs in the array from 1 to 8.
Fc9-type-16-icon.png Output Mode
Choose a single port for all LEDs, or to allocate them to arbitrary pins.
Fc9-type-19-icon.png Port
Fc9-type-16-icon.png Polarity
Active High = LEDs light when the chosen chip pin is ON Active Low = LEDs light when the chosen chip pin is OFF
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Alignment
Which 3D axis to align the copies along.
Fc9-type-15-icon.png Spacing
The distance between LEDs in the array. LEDs will be spaced symmetrically around the component centre. Use a negative value to reverse the order of the LEDs.
Fc9-type-7-icon.png Reverse
Reverse the direction of the LEDs.
Fc9-type-16-icon.png Show
Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Fc9-type-10-icon.png Property
Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text.
Fc9-type-16-icon.png Label Position
Whether to display the pin labels next to each LED
Fc9-type-1-icon.png LED color
The on colour for the LEDs, the off colour is calculated automatically from this.
Fc9-type-1-icon.png Label color
Color of the pin labels.
