Component: One Wire Dummy (Misc)
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.4
Category Misc
One Wire Dummy component
Low level routines for controlling or interacting with a standard one wire interface.
Please click here to download the component source project: FC_Comp_Source_temp/One_Wire_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/One_Wire_Dummy.fcfx
BusReset
BusReset
Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse. Returns 0 if a presense pulse was detected Returns 1 no device was detected
- BOOL Return
GetDeviceCount
GetDeviceCount
GetIDByte
GetIDByte
Returns byte ectet of the 64-Bit lasered ROM code, 255 on error
- BYTE Device
Device ID - Range: 0 - NumDevices - 1
- BYTE ByteIndex
Index of the data byte. 0=FamilyCode, 1-6=Serial, 7=CRC
Sets up the 1-Wire output pin ready for communications.
MatchROM
MatchROM
Performs a reset followed by the MatchROM code and then the 8-bit ROM code.
- BYTE FamilyCode
- BYTE SerialNumber
ReceiveByte
ReceiveByte
ScanBus
ScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
SkipROM
SkipROM
Performs a bus reset and the sends the SkipROM command byte
TransmitByte
TransmitByte
Transmit a byte to the one wire bus a bit at a time
- BYTE Command
