Component: Potentiometer (Analog Input)
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Category Analog Input
Potentiometer component
Please click here to download the component source project: FC_Comp_Source_temp/Potentiometer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Potentiometer.fcfx
Potentiometer Example
Ev_Start
Ev_Start
Broadcast to all components that simulation is starting
- ULONG Return
GetValue
GetValue
Get the Float value, between lower and upper bounds. Used on App Developer
- FLOAT Return
ReadAsByte
ReadAsByte
Read the ADC as a byte
ReadAsFloat
ReadAsFloat
Reads the ADC as a direct voltage
- FLOAT Return
ReadAsInt
ReadAsInt
Read the ADC at full bit depth
- INT Return
ReadAsVoltage
ReadAsVoltage
- FLOAT Return
SetValue
SetValue
Sets the Float value, between lower and upper bounds. Used on App Developer
- FLOAT Value
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Component Label
User Label Text
Text to display
Scale Range
Show Connection Label
Show Pin Value
Colour Style
Style
Type
Scale
Lower Bound
Upper Bound
Major Tick Step
Minor Tick Step
Label Format
Closed
Start Angle
End Angle
