Component: Serial Flash (W25) (EEPROM)
Revision as of 12:03, 3 February 2023 by Wiki bot (talk | contribs)
Category EEPROM
Serial Flash (W25) component
Component to allow support for the Winbond W25 range of SPI Flash devices. Compatible with various sizes of Flash including: 2Mb, 4Mb, 8Mb, 32Mb, 64Mb, 128Mb.
Please click here to download the component source project: FC_Comp_Source_temp/SerialFlash_W25Q.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/SerialFlash_W25Q.fcfx
EraseBlock
Fc9-comp-macro.png EraseBlock
Erases a block of data stored on the chip. Erase takes between 45 milliseconds and 2000 milliseconds to complete. Blocking mode is recommended to ensure write cycle is complete.
Fc9-u8-icon.png - BYTE EraseMode
0=4KB / 1=32KB / 2=64KB
Fc9-u16-icon.png - UINT PageAddress
Address bits A23-A8 : 16-bit Address - Range 0x0000 - 0xFFFF
Fc9-bool-icon.png - BOOL Blocking
Controls if the macro blocks until the erase cycle is complete. 0 = Don't Wait, 1 = Wait
EraseChip
Fc9-comp-macro.png EraseChip
Erases all data stored on the chip. Chip erase takes between 20 seconds and 100 seconds to complete. Blocking mode is recommended to ensure write cycle is complete.
Fc9-comp-macro.png Initialise
Initialises the SPI bus ready for communications.
ReadDataArray
Fc9-comp-macro.png ReadDataArray
Reads up to 256 data bytes starting from the specified address. Note that all bytes will be read from the same page.
Fc9-u8-icon.png - BYTE ByteAddress
A7-A0 : 8-bit Address within the page - Range 0x00 - 0xFF
Fc9-u8-icon.png - BYTE Count
Number of bytes to read.
Fc9-u8-icon.png - BYTE Data
Byta array to store the incoming read data.
ReadDataByte
Fc9-comp-macro.png ReadDataByte
Reads a single data byte from the specified address.
ReadStatus
Fc9-comp-macro.png ReadStatus
Reads one of the internal status registers on the device
Fc9-u8-icon.png - BYTE Reg
Selects which status register to read, 0 = Status or 1 = Status 2.
ReadUniqueID
Fc9-comp-macro.png ReadUniqueID
Reads the 8-byte unique identifier from the IC. Useful if you need each board to have it's own guarenteed unique address or identifier.
Fc9-u8-icon.png - BYTE ID
8-Byte data array to store the unique ID read back from the IC.
WriteControl
Fc9-comp-macro.png WriteControl
Enables or disables writing for things like erasing and programming. Writes must be enabled after a power on reset and again after an erase command.
Fc9-bool-icon.png - BOOL Status
1 = Write Enabled, 0 = Write Protected
WriteDataArray
Fc9-comp-macro.png WriteDataArray
Writes an array of data bytes atarting at the specified address. Writes must be enabled and memory locations must be erased for data writes to function correctly. Note that all bytes will be written to the same page.
Number of bytes to write.
WriteDataByte
Fc9-comp-macro.png WriteDataByte
Writes a single data byte to the specified address. Writes must be enabled and memory locations must be erased for data writes to function correctly.
Data byte to write
Fc9-conn-icon.png Flash Properties
Fc9-type-16-icon.png Memory Size
Sets the size of the flash memory available on the chip.
Fc9-type-21-icon.png Number Bytes
Fc9-type-21-icon.png Number Pages
Fc9-conn-icon.png SPI Properties
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-conn-icon.png Simulation
Decides how the simulation handles the data. No - Do no SPI simulation and allow all simulation data to come from a local text file. Yes - Use SPI simulation for use with Injector components etc.
Fc9-conn-icon.png File Simulation
Fc9-type-10-icon.png Simulation File
Name of file to use to hold the contents of the simulated flash memory. $(srcdir) assigns the file to the same folder as the Flowcode project file.
Fc9-type-21-icon.png Unique ID Lower 32-bit
Fc9-type-21-icon.png Unique ID Upper 32-bit
