Component: WAV Player ROM (File)
Revision as of 12:03, 3 February 2023 by Wiki bot (talk | contribs)
Category File
WAV Player ROM component
Stores an audio WAV file in ROM and contains component macros to allow the WAV file to be streamed out. Compatible with analogue outputs such as DAC or PWM.
Please click here to download the component source project: FC_Comp_Source_temp/WAV_Player.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/WAV_Player.fcfx
EndOfFile
EndOfFile
A simple check to see if we are at the end of the file. Returns 0 if we and not yet at the end fo the file. Returns 1 if we are at the end of the file.
- BOOL Return
GetBitsPerSample
GetBitsPerSample
Returns the number of bits per sample.
GetNextSample
GetNextSample
Retreives the value for the next sample and auto increments the file pointer. Ideally this function should be called as part of a timer interrupt at the sample rate. The value returned should be passed onto a means of analogue output e.g. a DAC or PWM.
GetNumChannels
GetNumChannels
Returns the number of audio channels stored in the WAV file.
SetFilePointer
SetFilePointer
Allows direct control of the file pointer. Write the file pointer to 0 to reset the pointer to the beginning of the file. Write the file pointer to 0xFFFFFFFF to force the pointer to the end of the file.
- ULONG Pointer
Range: 0x0 to 0xFFFFFFFF, 0 = Beginning of file
WAV File
WAV File to Embed into the ROM Flash memory.
File Status
Displays diagnostic data about the selected file.
Num Channels
Number of audio channels encoded in the WAV file. 1 indicates a MONO audio stream. 2 indicates a STEREO autio stream.
Sample Rate
The rate in samples per second at which the WAV file was recorded.
Bits Per Sample
The number of bits used to store a single sample.
Byte Rate
The number of data bytes per second that need to be processed in order to maintain playback.
ROM Bytes
Number of bytes of ROM that will be required to store the WAV file.
