Component: Component Labels (Misc)
Revision as of 12:03, 3 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.2
Category Misc
Component Labels component
Automatically generates labels for all panel objects and components in a given context. Labels will always face the camera, and can show the name of each object, or any chosen property. Nesting can be used so that components within components are labelled, and so on.
Please click here to download the component source project: FC_Comp_Source_temp/auto_labels.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/auto_labels.fcfx
Hide
Fc9-comp-macro.png Hide
Hides all labels.
SetColor
Fc9-comp-macro.png SetColor
Sets the color of the labels. Note that this affects all nesting levels, so any nesting level specific colors set in the properties panel will be overridden.
Fc9-u32-icon.png - ULONG Color
Color to set the labels to.
SetTarget
Fc9-comp-macro.png SetTarget
Set the target object. All items within the scope of this object will be given labels, not the taget object itself. If the target is set to zero or 'this', all objects in the current scope will be labelled.
Fc9-h32-icon.png - HANDLE target
ShowNames
Fc9-comp-macro.png ShowNames
Sets the labels to show the names of objects.
ShowProperty
Fc9-comp-macro.png ShowProperty
Sets the labels to show a named property of each object.
Fc9-string-icon.png - STRING Property
Name of the property to show.
Update
Fc9-comp-macro.png Update
Refresh the labels after a change.
Fc9-type-16-icon.png Show
Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Fc9-type-7-icon.png Auto Update
Automatically update the labels whenever panel items are added, deleted or re-named.
Fc9-type-7-icon.png Auto Target
When auto target is on, the auto labeller will label every item in its own context. When off, the "SetTarget" macro must be used to set the scope of the labeller.
Fc9-conn-icon.png Appearance
Fc9-type-1-icon.png Color
Color of the labels text.
Fc9-type-2-icon.png Background
Color for label backgroiunds - may be transparent.
Fc9-type-7-icon.png Always On Top
Whether labels should always be draw on top of other objects.
Fc9-conn-icon.png Size
Fc9-type-15-icon.png Scale
Sets the basic size (text height) of the labels.
Fc9-type-7-icon.png Follow Zoom
Whether labels get bigger and smaller when the panel is zoomed in and out.
Fc9-conn-icon.png Offset
Fc9-type-16-icon.png Auto
Attempt to automatically move the label to the side of the object. Choose a positive or negative offset in any of the three axes. When 'off' is chosen, you will be able to enter manual offsets along each axis.
Fc9-conn-icon.png Nesting
Fc9-type-16-icon.png Nesting
Whether to label child items of groups, groups within groups etc. Off - only items at the same level as the labeller get labelled. Nest levels - how many 'generations' to iterate into groups. Show Leaves - does not label groups, but labels all individual items, no matter how far nested.
