Component: LED MultiColour Bi (5mm, PCB) (LED)
| Author | Matrix Ltd |
| Version | 1.1 |
| Category | LED |
LED MultiColour Bi (5mm, PCB) component
An industry standard 5mm diameter bi-colour LED. Any color may be chosen, and the leads trimmed to length.
Please click here to download the component source project: FC_Comp_Source_temp/led_5mm_bicolour.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/led_5mm_bicolour.fcfx
A Bi Colour LED should be connected between two microcontroller I/O pins as shown below.
LEDOff
| LEDOff | |
| Switches off the LED | |
LEDOneOn
| LEDOneOn | |
| Switches on LED one | |
LEDSetState
| LEDSetState | |
| Controls the state of the LED. 0=Off 1=LED Colour 1 2=LED Colour 2 | |
| State | |
| 0=Off, 1=Pin1 High & Pin2 Low, 2=Pin1 Low & Pin2 High | |
LEDTwoOn
| LEDTwoOn | |
| Switches on LED two | |
