Component: Advanced String Functions (Utility)
Revision as of 12:17, 3 February 2023 by Wiki bot (talk | contribs)
Category Utility
Advanced String Functions component
A component designed to add more advanced functions to the existing built-in string library.
Please click here to download the component source project: FC_Comp_Source_AdvancedStringFunctions.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AdvancedStringFunctions.fcfx
Explode
The explode functions use a delimiter to split a string up into an array.
For example "1,2,3,4" using the delimiter ',' would create {1,2,3,4}.
Implode
The implode functions do the reverse and create a string from an array.
for example {1,2,3,4} using the delimiter ',' would create "1,2,3,4".
All of the string functions assume that your string variable is large enough to store the data being passed into it. Overflowing the bounds of the string could lead to RAM corruption which could effect the operation of your program.
Contains
Fc9-comp-macro.png Contains
Scans a string to see if it contains a specific substring. Returns 1 if found, otherwise returns 0.
Fc9-string-icon.png - STRING StrData
Data string to scan
Fc9-string-icon.png - STRING StrMatch
String to look for in the data
ExplodeToByteArray
Fc9-comp-macro.png ExplodeToByteArray
Takes an ASCII string and using a delimiter converts it into an array of bytes. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {1,2,3,4}
Fc9-string-icon.png - STRING StringInput
Data string e.g. "1,2,3,4"
Fc9-u8-icon.png - BYTE Delimiter
Delimiting character byte for example ','
Fc9-u8-icon.png - BYTE DataArray
Data array to hold the numberic values found
Fc9-u16-icon.png - UINT MaxCount
Maximum number of values to return
ExplodeToFloatArray
Fc9-comp-macro.png ExplodeToFloatArray
Takes an ASCII string and using a delimiter converts it into an array of floats Returns the number of values discovered and placed into the DataArray, e.g. "1.1,2.2,3.3,4.4" would become {1.1,2.2,3.3,4.4}
Fc9-f32-icon.png - FLOAT DataArray
ExplodeToINTArray
Fc9-comp-macro.png ExplodeToINTArray
Takes an ASCII string and using a delimiter converts it into an array of integers. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {1,2,3,4}
Fc9-u16-icon.png - UINT DataArray
ExplodeToStringArray
Fc9-comp-macro.png ExplodeToStringArray
Takes an ASCII string and using a delimiter converts it into an array of strings. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {"1","2","3","4"}
Fc9-string-icon.png - STRING DataArray
FormattedStringFloat
Fc9-comp-macro.png FormattedStringFloat
Converts a floating point value to a string of a fixed size. The value 5 with a length of 3 and a character of '0' would generate "003"
value to format
Fc9-u8-icon.png - BYTE MinLength
The minimum length you want the string to be
Fc9-u8-icon.png - BYTE PaddChar
Added character to padd the string with e.g. ' ' or '0'
Fc9-u8-icon.png - BYTE Precision
Number of decimal points to add
FormattedStringINT
Fc9-comp-macro.png FormattedStringINT
Converts a signed int to a string of a fixed size. The value 5 with a length of 3 and a character of '0' would generate "003"
Fc9-s16-icon.png - INT Value
value to format
ImplodeFromByteArray
Fc9-comp-macro.png ImplodeFromByteArray
Creates an ASCII string from an array of byte values. Places a delimiter in between each value. e.g. {1,2,3,4} would become "1,2,3,4"
Fc9-u16-icon.png - UINT Count
Number of values held in the array
Delimiter to add between values
ImplodeFromFloatArray
Fc9-comp-macro.png ImplodeFromFloatArray
Creates an ASCII string from an array of float values. Places a delimiter in between each value. e.g. {1.1,2.2,3.3,4.4} would become "1.1,2.2,3.3,4.4"
Number of decimal points to add to each float value
ImplodeFromINTArray
Fc9-comp-macro.png ImplodeFromINTArray
Creates an ASCII string from an array of integer values. Places a delimiter in between each value. e.g. {1,2,3,4} would become "1,2,3,4"
ImplodeFromStringArray
Fc9-comp-macro.png ImplodeFromStringArray
Creates an ASCII string from an array of string values. Places a delimiter in between each value. e.g. {"1","2","3","4"} would become "1,2,3,4"
InsertInto
Fc9-comp-macro.png InsertInto
Inserts a string into another string at the specified index position.
Fc9-string-icon.png - STRING DataString
Data string to ammend
Fc9-string-icon.png - STRING Insert
Data to insert
Fc9-u16-icon.png - UINT InsertionIndex
Index location in the string to insert the data
PositionOf
Fc9-comp-macro.png PositionOf
Scans a string to see if it contains a specific substring. Returns the location in the string if found, otherwise returns -1.
Data string to scan
Fc9-u16-icon.png - UINT SearchFrom
Starting index for the search, default 0.
Fc9-s16-icon.png - INT Return
RemoveFrom
Fc9-comp-macro.png RemoveFrom
Allows a set number of characters to be removed from a starting location in a string.
Fc9-u16-icon.png - UINT CharsToRemove
Number of characters to remove from the string
Fc9-u16-icon.png - UINT StartingIndex
Index location in the string to delete the data
SearchAndReplace
Fc9-comp-macro.png SearchAndReplace
Attempts to find a specific string inside the data string and if found replaces with the provided replacement string. Returns the number of times the search pattern was found.
Data string to scan
Fc9-string-icon.png - STRING StrSearch
Fc9-string-icon.png - STRING StrReplace
String to insert into the data
