Component: Brushless Motor (Standard) ()
Revision as of 12:18, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.1
Category
Brushless Motor (Standard) component
A small brushless motor component designed to be driven from a three phase ESC. The ESC would be driven using the Servo Motor Controller component.
Please click here to download the component source project: FC_Comp_Source_temp/BrushlessMotor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/BrushlessMotor.fcfx
No examples here yet
ESC Type
Selects if the ESC is capable of operating the motor in one or two directions. A R/C car ESC would likely be Bi-Directional whereas a helicopter ESC would be Uni-Directional.
Link To...
Select a panel object here to connect it 'mechanically' to the servo's actuator. The selected object will now be moved whenever the servo position changes. NB) To move multiple objects, first group the objects, and then select the group.
Reverse Output
Some manufacturers motors may rotate in different ways to others. Changing this property allows you to flip the direction of the simulated motor to better match with the real world hardware.
