Component: Temp / Humidity (DHT11) (Environmental)
| Version | 1.1 |
| Category | Environmental |
Temp / Humidity (DHT11) component
The DHT11 temperature and humidity sensor is a popular sensor allowing the ambient temperature and relative humidity to be monitored digitally. Humidity Range = 20% - 90% +/- 5% Temperature Range = 0 - 50 Degrees C +/- 2 Degrees C
Please click here to download the component source project: FC_Comp_Source_temp/DHT11.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/DHT11.fcfx
Example Program showing how to sample the DHT11 sensor and show the temperature and humidity on an LCD.
DHT11 Example
GetHumidityFloat
| GetHumidityFloat | |
| Gets the humidity returned by calling SampleSensor as a floating point number. | |
GetHumidityReal
| GetHumidityReal | |
| Gets the real number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 8. | |
GetHumidityString
| GetHumidityString | |
| Gets the humidity returned by calling SampleSensor as a string. | |
GetHumidityWhole
| GetHumidityWhole | |
| Gets the whole number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 15. | |
GetTempFloat
| GetTempFloat | |
| Gets the temperature returned by calling SampleSensor as a floating point number. | |
GetTempReal
| GetTempReal | |
| Gets the real number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 8. | |
GetTempString
| GetTempString | |
| Gets the temperature returned by calling SampleSensor as a string. | |
GetTempWhole
| GetTempWhole | |
| Gets the whole number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 15. | |
SampleSensor
| SampleSensor | |
| Communicates with the DHT11 sensor and receives the temperature and humidity readings. Returns 0 for success, 1 for no communication detected and 2 for checksum error. | |
