Component: Math (DSP Operators)
Revision as of 12:18, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Operators
Math component
Component to combine together two DSP buffers into one an index at a time. Functions include: Add, Average, Difference, Max, Min, Subtract
Please click here to download the component source project: FC_Comp_Source_temp/DSP_Math.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/DSP_Math.fcfx
Here is a example file which generates a sine wave and a triangle wave and then uses the DSP sum component to merge together the two signals. DSPSum Here is the kind of waveform you can expect to see using the scope window when adding the two signals together.
Here is the kind of waveform you can expect to see using the scope window when subtracting the two readings.
Here is the kind of waveform you can expect to see using the scope window when taking the maximum of the two signals.
Here is the kind of waveform you can expect to see using the scope window when taking the minimum of the two signals.
Here is the kind of waveform you can expect to see using the scope window when taking the average between the two signals.
Here is the kind of waveform you can expect to see using the scope window when taking the difference between the two signals.
Calculate
Calculate
Performs a single calculation on the two input buffers and provides a result into the output buffer
CalculateArray
CalculateArray
Connect To A
Connect To B
Buffer Size
Buffer Type
Sets the buffer data type.
Direction
Sets the data direction flow of the component
Calculation
Sum Type
Defines the type of calculation performed on the two input buffers to obtain the output value. Data shown in brackets indicates operation  ? = a decision followed by the true value and then the false value seperated with a colon.
