Component: Simulated Control Load (DSP Operators)
Revision as of 12:18, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Operators
Simulated Control Load component
Allows a simulated load to be connected to the DSP network allowing you to model external factors such as Motor Speed, Motor Position, Temperature, Humidity, Pressure, Flow etc. Useful when used with a feedback based control system.
Please click here to download the component source project: FC_Comp_Source_temp/DSP_SimLoad.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/DSP_SimLoad.fcfx
SimulateLoad
SimulateLoad
Simulates a load change with a new control value being applied and a new feedback signal gathered from the output.
SimulateLoadArray
SimulateLoadArray
Passes an entire buffer into the delay buffer and spits out a delayed version of the buffer at the other end
Connect To
Buffer Size
Buffer Type
Sets the buffer data type.
Direction
Sets the data direction flow of the component
Load
Model Type
Model Order
The order of a differential equation is the highest degree of derivative present in that equation. A system whose input-output equation is a second order differential equation is called Second Order System.
1st Order
Determines to the response of the syecific order within the system. Output = (OldOutput * (1 - Order)) + (NewInput * Order)
2nd Order
Initial Output
