Component: Gyroscope 3-Axis (L3G4200D) (Movement Orientation)
Revision as of 12:20, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Movement Orientation
Gyroscope 3-Axis (L3G4200D) component
Interface to the L3G4200D three axis digital gyroscope. Panel GUI can be used to simulate incoming data for testing.
Please click here to download the component source project: FC_Comp_Source_temp/Gyroscope_L3G4200D.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Gyroscope_L3G4200D.fcfx
GetX
Fc9-comp-macro.png GetX
Returns the previously sampled X axis data
Fc9-s16-icon.png - INT Return
GetY
Fc9-comp-macro.png GetY
Returns the previously sampled Y axis data
GetZ
Fc9-comp-macro.png GetZ
Returns the previously sampled Z axis data
Fc9-comp-macro.png Initialise
Initialise the component.
ReadRegister
Fc9-comp-macro.png ReadRegister
Read the data byte at the given address of the device
Fc9-u8-icon.png - BYTE Reg
address of the register to be read
SampleDevice
Fc9-comp-macro.png SampleDevice
Reads the Axis data from the device
WriteRegister
Fc9-comp-macro.png WriteRegister
Writes the data byte to the given address of the device. Returns 0 if successful
address of register to be written with data byte
Fc9-u8-icon.png - BYTE Data
data byte to be written to device register
Fc9-type-16-icon.png Output Data Rate
Fc9-type-16-icon.png Full Scale Selection
Specifies the maximum angular speed which the sensor can measure in degrees per second
Fc9-type-16-icon.png X Axis
Fc9-type-16-icon.png Y Axis
Fc9-type-16-icon.png Z Axis
Fc9-type-10-icon.png Label
Fc9-conn-icon.png Connection
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Simulate Comms
