| Author
Matrix TSL
| Version
1.0
| Category
Movement Orientation
Gyroscope 3-Axis I2C (L3GD20) component
Interface to the L3GD20 three axis digital gyroscope. Panel GUI can be used to simulate incoming data for testing.
Please click here to download the component source project: FC_Comp_Source_temp/Gyroscope_L3GD20_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Gyroscope_L3GD20_I2C.fcfx
GetGyroReading
GetGyroReading
| Collects one of the gyroscope readings from the last sample.
- BYTE
Axis
| 0=X, 1=Y, 2=Z
- INT
| Initialise the component. Returns 0 if successful
- BYTE
ReadRegister
ReadRegister
| Read the data byte at the given address of the device
- BYTE
Reg
| address of the register to be read
- BYTE
SampleDevice
SampleDevice
| Reads the Axis data from the device.
- BYTE
WriteRegister
WriteRegister
| Writes the data byte to the given address of the device. Returns 0 if successful
- BYTE
Reg
| address of register to be written with data byte
- BYTE
data
| data byte to be written to device register
- BYTE
Output Data Rate
| Specifies the gryoscope sample data rate
Full Scale Selection
| Specifies the maximum angular speed which the sensor can measure in degrees per second
Bandwidth Selection
| Linked with data rate, See device datasheet table 21.
Filter Enable
| Enables automatic internal filtering on the gyro data
X Axis
| Enables or disables the selected axis allowing it to generate data or be switched off to save power.
Y Axis
Z Axis
Connection
Address Pin
| The state of the SDO address pin. 0 = Connected to GND 1 = Connected to VCC
| Channel selection
SDA
SCL
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
Simulate Comms
| Controls where the simulation data comes from. Component GUI - Data comes from the sliders on the component panel GUI API - Comms data is sent and received via an API component
