| Author
Matrix TSL
| Version
2.0
| Category
Movement Orientation
Gyroscope 3-Axis SPI (L3GD20) component
Allows access to a three axis digital gyroscope via an SPI interface. Useful for gaming, VR, motion control, navitagion and robotics.
Please click here to download the component source project: FC_Comp_Source_temp/Gyroscope_L3GD20_SPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Gyroscope_L3GD20_SPI.fcfx
GetGyroReading
GetGyroReading
| Collects one of the gyroscope readings from the last sample.
- BYTE
Axis
| 0=X, 1=Y, 2=Z
- INT
| Initialises the SPI bus ready to communicate with the sensor.
ReadRegister
ReadRegister
| Reads a single register from the gyroscope and returns the value as a byte.
- BYTE
Address
- BYTE
SampleDevice
SampleDevice
| Collects the gyro readings from the device.
WriteRegister
WriteRegister
| Writes a single register on the gyroscope.
- BYTE
Address
- BYTE
Data
Sensor Configuration
Output Data Rate
| Specifies the gryoscope sample data rate
Full Scale Selection
| Specifies the maximum angular speed which the sensor can measure in degrees per second
Bandwidth Selection
| Linked with data rate, See device datasheet table 21.
Filter Enable
| Enables automatic internal filtering on the gyro data
X Axis
| Enables or disables the selected axis allowing it to generate data or be switched off to save power.
Y Axis
Z Axis
SPI Connection
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MISO
CLK
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Simulation Type
