Component: LCD (ST7032i) (Alphanumeric)
Revision as of 12:20, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.1
Category Alphanumeric
LCD (ST7032i) component
Standard alphanumeric LCD based on the ST7032i LCD driver IC connected using I2C.
Please click here to download the component source project: FC_Comp_Source_temp/LCD_ST7032i.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LCD_ST7032i.fcfx
Clear
Fc9-comp-macro.png Clear
ClearLine
Fc9-comp-macro.png ClearLine
Fc9-u8-icon.png - BYTE Line
Command
Fc9-comp-macro.png Command
Fc9-u8-icon.png - BYTE instruction
Cursor
Fc9-comp-macro.png Cursor
Fc9-u8-icon.png - BYTE x
Fc9-u8-icon.png - BYTE y
PrintAscii
Fc9-comp-macro.png PrintAscii
Fc9-u8-icon.png - BYTE character
PrintFloat
Fc9-comp-macro.png PrintFloat
Fc9-f32-icon.png - FLOAT Number
Fc9-u8-icon.png - BYTE DecimalPlaces
PrintFormattedNumber
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
Allows you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
PrintString
Fc9-comp-macro.png PrintString
RAMWrite
Fc9-comp-macro.png RAMWrite
Fc9-u8-icon.png - BYTE Index
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
ScrollDisplay
Fc9-comp-macro.png ScrollDisplay
Fc9-u8-icon.png - BYTE position
Fc9-u8-icon.png - BYTE direction
Start
Fc9-comp-macro.png Start
Startup routine required by the hardware device.
Fc9-conn-icon.png I2C Config
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png LCD Configuration
Fc9-type-16-icon.png Voltage
Configures things like the display default contrast and follower
Fc9-type-16-icon.png Rows
Fc9-type-16-icon.png Columns
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-1-icon.png Text Colour
Colour of the font characters drawn on the display
Fc9-type-1-icon.png Text Background
Colour surrounding the font characters drawn on the display
Fc9-type-1-icon.png Display Background
Colour of the background of the display
Used to drive the comms durig simulation which can be used to: Data Recorder waveform generation Console Logging Data Injector to redirect the data e.g. to a SCADA slave connected to the physical hardware
