| Author
Matrix Ltd
| Version
0.1
| Category
LED (Generic) component
Basic LED component using simple geometric shapes.
Please click here to download the component source project: FC_Comp_Source_temp/LED_Shape.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LED_Shape.fcfx
Pin
| Chip pin to connect the LED to. NB) LED will not change state unless there is a pin connection.
Polarity
| Active High: Pin true -> On color, Pin false -> Off color. Active Low: Pin true -> Off color, Pin false -> On color.
On Color
| The color that the LED will take when lit. The off colour is calculated automatically to be a darker shade of the same hue.
Shape
| Shape of the LED.
Size
Width
| Width of the LED shape.
Height
| Height of the LED shape.
Depth
| Depth of the LED shape.
Show
| Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Property
| Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text.
Color
| Color of the labels text.
Scale
| Sets the basic size (text height) of the labels.
Follow Zoom
| Whether labels get bigger and smaller when the panel is zoomed in and out.
Position
| Set the position of the label relative to the component.
