Component: Airplane Landing Gear (Scenarios)
Revision as of 12:20, 3 February 2023 by Wiki bot (talk | contribs)
Category Scenarios
Airplane Landing Gear component
A simulation of an Airplane Landing Gear containing, switches, locking mechanisms and retracting landing gear.
Please click here to download the component source project: FC_Comp_Source_temp/LandingGearComponent_v002.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/LandingGearComponent_v002.fcfx
Airplane Landing Gear Scenario
FrontDoorCloseSwitch
Fc9-comp-macro.png FrontDoorCloseSwitch
Test to see if the Front door will touch the collision switch by its original position. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended
FrontDoorLocks
Fc9-comp-macro.png FrontDoorLocks
Will lock or unlock the front doors depending on the number given to the paremeter.
Fc9-u8-icon.png - BYTE OpenOrClose
Open =1 Close=0
FrontDoorOpenSwitch
Fc9-comp-macro.png FrontDoorOpenSwitch
Test to see if the Back door will touch the collision switch by its final position. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended
FrontDoors
Fc9-comp-macro.png FrontDoors
Will allow the front doors to open.
Fc9-u8-icon.png - BYTE Direction
Drops the door down or close them. 0 = Close 1 = Open
LandingGear
Fc9-comp-macro.png LandingGear
Retracts and drops the landing gear.
Drop the wheel down or retracts them. 0 = Retracts 1 = Drop
LandingGearDownSwitch
Fc9-comp-macro.png LandingGearDownSwitch
Test to see if the Landing Gear will touch the collision switch by its final position. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended
LandingGearUpSwitch
Fc9-comp-macro.png LandingGearUpSwitch
Test to see if the Landing Gear will touch the collision switch above it. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended
RearDoorCloseSwitch
Fc9-comp-macro.png RearDoorCloseSwitch
Test to see if the rear door will touch the collision switch by its original position. If it does, will return true. and stop movement.
RearDoorLocks
Fc9-comp-macro.png RearDoorLocks
Will unlock or lock the rear doors
Open =1 Close =0
RearDoorOpenSwitch
Fc9-comp-macro.png RearDoorOpenSwitch
Test to see if the rear door will touch the collision switch by its final position. If it does, will return true. and stop movement.
RearDoors
Fc9-comp-macro.png RearDoors
Will allow the rear door to open
Drop the door down or close them. 0 = Close 1 = Open
