Component: MIAC NXT AllCode API (AllCode)
Revision as of 12:21, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.1
Category AllCode
MIAC NXT AllCode API component
Controls the MIAC NXT hardware loaded with the MIAC NXT AllCode firmware. Usefull for SCADA, Control or Test applications. Compatible with USB / Bluetooth / Wifi / Ethernet
Please click here to download the component source project: FC_Comp_Source_temp/MIAC_NXT_AllCode_Component_Source.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/MIAC_NXT_AllCode_Component_Source.fcsx
DisplayClear
Fc9-comp-macro.png DisplayClear
Clears the MIAC display
DisplayCursor
Fc9-comp-macro.png DisplayCursor
Sets the cursor position for the MIAC display
Fc9-u8-icon.png - BYTE X
Range: 0-21
Fc9-u8-icon.png - BYTE Y
Range: 0-3
DisplayFloat
Fc9-comp-macro.png DisplayFloat
Prints a floating point number to the MIAC display starting from the current cursor position.
Range: Float
Fc9-u8-icon.png - BYTE NumDP
Number of decimal places to display
DisplayNumber
Fc9-comp-macro.png DisplayNumber
Prints a number to the MIAC display starting from the current cursor position.
Fc9-s32-icon.png - LONG Value
Range: Signed Long
DisplayPixel
Fc9-comp-macro.png DisplayPixel
Controls a single pixel on the MIAC display
Range: 0-119
Range: 0-31
Fc9-bool-icon.png - BOOL State
Range: 0-1
DisplayPrint
Fc9-comp-macro.png DisplayPrint
Prints a string to the MIAC display starting from the current cursor position.
Fc9-string-icon.png - STRING data
Range: 0-21
GetAPIVersion
Fc9-comp-macro.png GetAPIVersion
Gets the API version of the MIAC NXT AllCode Firmware. Useful to see if the MIAC NXT is responding to commands.
ReadAnalogInput
Fc9-comp-macro.png ReadAnalogInput
Reads a single analog input with range 0 to 4095 corresponding to input voltage 0V to +V.
Range: 1 - 8
ReadDigitalInput
Fc9-comp-macro.png ReadDigitalInput
Reads a single digital input.
Range: 1 - 8
ReadDigitalInputs
Fc9-comp-macro.png ReadDigitalInputs
Reads all digital inputs at once and returns as a binary value. Input 1 = Bit 0 Input 8 = Bit 7
ReadKey
Fc9-comp-macro.png ReadKey
Reads a keypress from the keypad. Returns 0 for no keypress or 1-9 for a valid keypress. 1 = TopLeft, 2=TopMiddle, 3=TopRight, 4=CenterLeft etc
SetAPIVerbose
Fc9-comp-macro.png SetAPIVerbose
Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
Fc9-bool-icon.png - BOOL Mode
Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
WriteRelay
Fc9-comp-macro.png WriteRelay
Allows a single relay to be switched on or off.
Range 1-2
Fc9-bool-icon.png - BOOL Value
0 = Off, 1 = On
WriteRelays
Fc9-comp-macro.png WriteRelays
Allows all relays to be switched on or off in a single command.
Fc9-u8-icon.png - BYTE Value
Range: 0-3 or 0b00 to 0b11
WriteTran
Fc9-comp-macro.png WriteTran
Allows a single transistor output to be switched on or off.
Range 1-6 where 1=A / 2=B / 3=C / 4=D / 5=E / 6=F
0 = Off, 1 = On
WriteTranPWMDuty
Fc9-comp-macro.png WriteTranPWMDuty
Sets the PWM duty on the selected channel.
Range: 1-4 Where 1=A / 2=B / 3=C / 4=D
Fc9-bool-icon.png - BOOL EnableOrState
1 = Enable / 0 = State
Fc9-u16-icon.png - UINT Duty
WriteTranPWMEnable
Fc9-comp-macro.png WriteTranPWMEnable
Allows pulse width modulated transistor outputs to be switched on or off.
PWM on Enable Pin or State Pin - 1 = Enable / 0 = State
Fc9-bool-icon.png - BOOL OnOrOff
1 = Enabled / 0 = Disabled
WriteTrans
Fc9-comp-macro.png WriteTrans
Allows all transistor outputs to be switched on or off in a single command.
Range: 0-63 or 0b000000 to 0b111111
Fc9-type-16-icon.png API Connection Type
API connection mode. COM - Bluetooth / RS232 / RS485 WIFI - Network
Fc9-type-7-icon.png Warnings On Error
Generates a warning dialogue if the communication to the device fails allowing the program to be ended.
Fc9-conn-icon.png Connection Properties
Fc9-type-7-icon.png Auto Detect
