Component: Proximity Switch Template (Sensors)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.2 |
| Category | Sensors |
Proximity Switch Template component
Polls a chosen panel object to test it's distance from this component. When the test object is within the detection range, the state of a pin is changed, and a User event generated. Used for building models of reed swicthes and hall sensors.
Please click here to download the component source project: FC_Comp_Source_temp/Proximity_base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Proximity_base.fcfx
Simple example showing the proximity detector component at work, when a proximity is detected the direction of the motor is reversed.
 Detector
Detector
ReadState
|   | ReadState |
| Get the current collision state. The 'Polarity' property will affect whether a collision is represented by a high or low state. | |
|  - BYTE | Return |
SetTarget
WaitUntilHigh
WaitUntilLow
