| Author
Matrix TSL
| Version
1.0
| Category
Analog Input
Joystick (Sparkfun Quiic) component
An XY sprung joystick with click switch allowing for easy user input control. Connected using I2C bus.
Please click here to download the component source project: FC_Comp_Source_temp/Sparkfun_Quiic_Joystick.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Sparkfun_Quiic_Joystick.fcfx
Traffic Light Scenario
ChangeI2CAddress
ChangeI2CAddress
| Allows the I2C Device address to be changed which in turn allows more then one RFID reader to sit on the same physical I2C bus. Returns 1 if succesful.
- BYTE
NewAddress
| Range: 8 to 119 or 0x08 - 0x77
- BOOL
CheckButton
| Checks to see if the button has been pressed since the last read of CheckButton or ReadButton.
- BOOL
| Initialises the I2C bus ready for communications with the module.
ReadAxis
ReadAxis
| Reads a single axis of the joystick and returns as a signed integer value.
- BYTE
Axis
| Range 0-1 Where 0=X, 1=Y
- BOOL
Type
| 0 = Signed (-512 to 511), 1 = Unsigned (0 to 1023)
- INT
ReadButton
| Checks to see if the button is currently pressed
- BOOL
Return To Center
| Decides if the joystick automatically returns to the center position when released. Yes: The joystick will return to the center when released. No: The joystick will remain in the current position when released.
Device Address
| External device address used to communicate with the module. Default 32 or 0x20
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
SDA
SCL
Stop Delay
Simulate Comms
| Controls if we are using the panel simulation or simulating the I2C calls for use with an I2C injector.
| Selects if the component pin connections are automatically generated on the data recorder window or not. Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion. No: Do not show the pin signals on the data recorder window.
API
| Specifies the injector component on the panel to interact with to provide comms simulation.
