Component: Slider control (Advanced Shapes)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.1 |
Category | Advanced Shapes |
Slider control component
A simple graphical interface for a vertical meter or slider control. This can be used within custom components to give them a way to display an analogue value, or to allow setting a value by clicking and dragging with the mouse.
Please click here to download the component source project: FC_Comp_Source_temp/slider.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/slider.fcfx
Simple example showing how to use the simulation slider component as a meter display for use in monitoring type applications.
Meters
GetValue
GetValue |
Gets the current value of the slider. This will be within the range set by the SetRange macro. | |
Return |
SetInteractive
SetInteractive |
Set whether the mouse can be used to change the slider value. | |
Enable |
Set true to allow clicks to set scale | |
Return |
SetRange
SetRange |
Set the minimum and maximum values that can be shown on the slider. | |
Min |
Min (start) value | |
Max |
Maximum (end) value | |
Return |
SetValue
SetValue |
Set the current value of the slider. This will override any value set by using the mouse. | |
Value |
The value to set. | |
Return |
ShowScale
ShowScale |
Set whether graduated marking are shown along the length of the slider. | |
Show |
True to show scale, else false | |
Return |
Properties |
