Component: Accel / Mag 6-Axis (LSM303DLHC) (Movement Orientation)
Revision as of 13:08, 7 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Movement Orientation
Accel / Mag 6-Axis (LSM303DLHC) component
LSM303DLHC Combined 6-Axis Accelerometer and Magnetometer sensors Useful for working out data such as Pitch and Yaw.
Please click here to download the component source project: FC_Comp_Source_AccelMag_LSM303DLHC.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AccelMag_LSM303DLHC.fcfx
CollectXYZData
CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
- BYTE Axis
- INT Return
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
SimReset1G
SimReset1G
SimSetAccelerometer
SimSetAccelerometer
Allows the XYZ slider values to be set via the simulation
- INT X
- INT Y
- INT Z
SimSetCompass
SimSetCompass
- INT X
- INT Y
- INT Z
UpdateAccelerometerData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
UpdateCompassData
UpdateCompassData
Reads from the compass and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
Write_Register
Write_Register
Writes a data value to a specific register on the accelerometer
- BYTE Reg
- BYTE Data
Sensor Options
Power Mode
Accel Data Rate
Accel Scale
Compass Data Rate
Compass Scale
Comms Mode
Specifies the communications mode. Interrupt - Wait for the interrupt pin to go high before allowing new data to be sampled. Polling - New data is sampled without needing to check the interrupt pin.
Bit Depth
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Sim Type
Controls how the simulation data is generated, via the component GUI or via a I2C API.
I2C
API
