Component: Analogue LED (Outputs)
Revision as of 13:08, 7 February 2023 by Wiki bot (talk | contribs)
Author
Category Outputs
Analogue LED component
An LED with variable brightness. Simulation Only. Brightness can be set either by macro call or by connection to an analogue pin.
Please click here to download the component source project: FC_Comp_Source_Analogue_LED.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Analogue_LED.fcfx
Example Program showing how to show the temperature in Celsius and Fahrenheit and expected ADC pin voltage on an LCD. FC6 Icon.png Analogue Sensors Example
SetBrightness
Fc9-comp-macro.png SetBrightness
Set the brightness of the LED.
Fc9-f32-icon.png - FLOAT Brightness
Brightness from 0.0 to 1.0
[[File:]] - Return
Fc9-type-6-icon.png Analogue
Choose an analogue pin to connect to the LED. When the analogue value changes, the LED brightness will be updated.
Fc9-conn-icon.png Color Range
Fc9-type-1-icon.png On Color
LED color when at maximum brightness
Fc9-type-1-icon.png Off Color
LED color when at minimum brightness
Fc9-type-7-icon.png Auto Off
When AutoOff is enabled, the Off Color is automatically set whenever the On Color is changed. The automatic off color will be the same hue as the on color, but 25% of the brightness.
Fc9-type-15-icon.png Minimum
Input value that gives the darkest LED color.
Fc9-type-15-icon.png Maximum
Input value that gives the brightest LED color.
Fc9-conn-icon.png Shape
Fc9-type-17-icon.png Target
A panel object to be treated as the illuminating part of the LED. If unconnected, a built-in default shape can be chosen.
Fc9-type-16-icon.png Shape
Choose a shape for the LED.
Fc9-type-15-icon.png Width
Width of the LED shape.
Fc9-type-15-icon.png Height
Height of the LED shape.
Fc9-type-15-icon.png Depth
Depth of the LED shape.
