| Author
Matrix TSL
| Version
1.0
| Category
Analog Output
DAC (MCP47x6) component
Component to drive a digital to analogue converter (DAC) IC from Microchip via an I2C interface. Compatible with MCP4706 (8-Bit), MCP4716 (10-Bit) and MCP4726 (12-Bit) devices.
Please click here to download the component source project: FC_Comp_Source_DAC_MCP47x6.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DAC_MCP47x6.fcfx
Disable
Disable
| Disables the DAC output.
Enable
Enable
| Enables the DAC Output.
| Configures the I2C peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated.
SetOutput
SetOutput
| Sets the output voltage of the DAC 8-Bit: Range 0-255 10-Bit: Range 0-1023 12-Bit: Range 0-4095
- UINT
DAC_Value
| The value to output to the DAC
DAC IC
| Selects which DAC IC is connected and therefore the bit depth available.
Disabled Pull Down
| Sets the pull down resistance when the IC's DAC output is disabled.
Voltage Reference
| Sets the Voltage reference option
Gain Option
| Provides a 1x or 2x gain on the output. For 2x gain the vref must be max 1/2 VCC.
Vref Voltage
| Reference Voltage, Used to calculate the Voltage resolution.
Steps
| Number of discrete output states available from the DAC.
Control Bits
| Number of digital control bits
Resolution
| Maximum output resolution based on number of control bits.
Voltage Resolution
| Specifies the Resolution per digital bit in terms of Voltage.
I2C Connections
User Address Bits
| Specifies the bottom three "user" bits of the I2C 7-bit address
| Channel selection
SDA
SCL
Stop Delay
Baud Select
| Baud rate option selector
| Baud rate to be used
Simulate Comms
