Component: DALI Slave (Comms: System)
Revision as of 13:09, 7 February 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: System
DALI Slave component
A serial based communications protocol designed for controlling lighting, specifically digitally controlled dimmable fluorescent ballasts. DALI requires the signals to be level shifted from VCC and GND to +9.5V - +25.5V and GND using external circuitry.
Please click here to download the component source project: FC_Comp_Source_DALI_Slave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DALI_Slave.fcfx
CheckForGroupAddress
Tests the 16-bit incoming data for the defined group address Returns 0 for no match, returns 1 for a match
- UINT Data
CheckForIndividualAddress
Tests the 16-bit incoming data for the defined individual address Returns 0 for no match, returns 1 for a match
- UINT Data
CollectDataByte
CollectDataByte
Returns the data byte from a 16-bit data packet
- UINT Data
CollectPacketType
CollectPacketType
Returns if the incoming packet was data or a command. Return of 0 = Data Return of 1 = Command
- UINT Data
Configures the UART serial interface.
ReceiveForwardFrame
ReceiveForwardFrame
Attempts to receive an 16-bit command from the master controller. 0xFFFF indicates timeout or no reply
TransmitBackwardFrame
Send out a 8-bit frame consisting of a data byte.
- BYTE Data
Data Byte
Serial Properties
TX Pin
RX Pin
DALI Slave Properties
Individual Address
Address ranging from 0-63
Group Address
Address ranging from 0-15
API
