Component: DMX-512 Master (Comms: System)
| Author | MatrixTSL |
| Version | 2.0 |
| Category | Comms: System |
DMX-512 Master component
A serial based communications protocol designed for controlling theatrical equipment such as dimmers, fog machines and intelligent lights. DMX-512 Slave devices are daisy chained together with a final 180R terminating resistor at the end of the chail. DMX requires the signal to be level shifted from VCC and GND to +2.5V and -2.5V.
Please click here to download the component source project: FC_Comp_Source_DMX-512_Master_SCADA.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_DMX-512_Master_SCADA.fcsx
DMX Master Example, reads the value of two ports using switch arrays to set the values and then transmits the data in a DMX packet.
For DMX 512 slave example see: DMX Slave
| Configures the UART serial interface. | |
SendDataChain
| SendDataChain | |
| Transmits the BREAK, MAB and StartCode followed by the contents of the data channels. | |
| StartCode | |
SetDataChannel
| SetDataChannel | |
| Sets the data byte in a data channel | |
| Channel | |
| DataValue | |
