Component: Humidity (EBM016) (EBM Modules)
Version | 2.0 |
Category | EBM Modules |
Humidity component
Humidity and temperature sensor using an SHT21 IC connected via I2C - as used by the Matrix e-block module EBM016. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
Please click here to download the component source project: FC_Comp_Source_EBM016v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM016v1.fcfx
This example reads the temperature and humidity levels from the sensor and displays the readings on the LCD.
GetHumidityData
GetHumidityData |
Returns the raw register pair value | |
Return |
GetHumidityInt
GetHumidityInt |
returns the relative Humidity reading as an integer value | |
Return |
GetHumidityReal
GetHumidityReal |
returns the Humidity reading as a float value | |
Return |
GetTemperatureData
GetTemperatureData |
Return |
GetTemperatureInt
GetTemperatureInt |
Return temperature reading as an integer value in degrees C | |
Return |
GetTemperatureReal
GetTemperatureReal |
Return temperature reading as a float value in degrees C | |
Return |
Initialise |
Initialises the component ready for I2C communications | |
Return |
