Component: Embed File (File)
Revision as of 13:10, 7 February 2023 by Wiki bot (talk | contribs)
Category File
Embed File component
A component to simplify the process of embedding files into ROM. Stores the file inside a ROM look up table.
Please click here to download the component source project: FC_Comp_Source_EmbedFile.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EmbedFile.fcfx
Basic example program which embeds a text file into the microcontrollers ROM memory and then prints the file out to a LCD display. EmbedFileExample Text file to go with the example, must be placed into the same directory as the Flowcode file.
File:TextFile.txt
Here is an archive which packages the example and text file together for you.
Embed File Example Files
The file is selected using the File component property.
Clicking the small arrow to the right of the property and selecting Browse allows you to select a file using a Windows file explorer.
GetFileArray
GetFileArray
Reads a number of bytes from the file from the specified start address.
- UINT StartAddress
Address of the first byte to read
- UINT NumBytes
Number of bytes to read from the file
- BYTE Data
Variable to pass the data into
GetFileByte
GetFileByte
Reads a single byte from the file at the specified address.
- UINT Address
Address range 0 to NumBytesInFile - 1
GetFileLength
GetFileLength
Returns the file size in bytes.
File
File you wish to embed into the program
File Length
File size in bytes. Max recommended file size = 65535 bytes 8-bit PICs may struggle with files larger than 256 bytes.
ROM Size
Number of bytes available in the target device ROM memory
