Component: GLCD (Grove OLED) (OLED 1.12") (Graphical Monochrome)
Revision as of 13:10, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Monochrome
GLCD (Grove OLED) component
Graphical display component based on the Seed Studio Grove OLED 1.12" and 0.96" monochrome displays. Functions without the use of a read back by hosting the graphical memory using the microcontroller's RAM memory.
Please click here to download the component source project: FC_Comp_Source_GLCD_Grove_OLEDDisplay.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_Grove_OLEDDisplay.fcfx
BPlot
BPlot
- UINT X1
- UINT Y1
ClearDisplay
ClearDisplay
ControlContrast
ControlContrast
Sets the display contrast from 0 to 255.
- BYTE Contrast
Range 0 - 255, Default 207
ControlDisplay
ControlDisplay
Allows the display to be switched on and off
- BYTE Control
0=Off, 1=On
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
InvertDisplay
InvertDisplay
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SendCommand
SendCommand
- BYTE Command
SetBackgroundColour
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
Display Type
Display Version
Use Buffer
The buffer is used to store the display pixel data so that we can write new content to the display without effecting adjacent pixels. With the buffer disabled there is a high chance of display corruption. For example if drawing text that is not using a multiple of 8 pixels for the y axis. e.g. 0, 8, 16, 24 etc.
Buffer Size
Number of bytes used to buffer the display contents.
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Channel selection
SCL
SDA
Stop Delay
Baud Select
Baud rate to be used
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
Simulate Comms
Used to drive the comms durig simulation which can be used to: Data Recorder waveform generation Console Logging Data Injector to redirect the data e.g. to a SCADA slave connected to the physical hardware
