| Author
Matrix TSL
| Version
2.1
| Category
Misc
HBRIDGE component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the H-Bridge peripheral. Currently only supports compatible 8-bit PIC devices.
Please click here to download the component source project: FC_Comp_Source_HBRIDGE.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_HBRIDGE.fcfx
Half Bridge Application
A Half Bridge type output has two output signals A and B.
Full Bridge Application
Full Bridge type output has four output signals A, B, C and D.
A simple proof of concept example to drive a full bridge output with varying speed and direction.
PIC16F1937 H-Bridge Example
PIC16F18877 H-Bridge Example
Disable
Disable
| Disable this PWM Channel
Enable
Enable
| Enable this PWM Channel
GetList
GetList
| Returns CHANNEL or PRESCALE list from the FCD and updates the internal property
- STRING
Name
- STRING
GetValue
GetValue
| Returns Named property Value
- STRING
Name
- STRING
SetDirection
SetDirection
| Set the motor direction.
- BYTE
direction
| 0 = Forwards, 1 = Reverse
SetSpeed
SetSpeed
| Sets the motor speed by varying the PWM duty.
- UINT
duty
| Duty value 0 - 1023
SetValue
SetValue
| Sets the Value of the property PERIOD, PRESCALE or CHANNEL (if CHANNEL also updates the PORT from FCD)
- STRING
Name
- STRING
Value
Enable
Settings
| PWM Channel selector
Mode
| Selects between full bridge and half bridge output modes. Some H-Bridge channels may only have one mode in which case the property selector will only show the available mode.
Polarity
| Selects the active output voltage. Active high - Pins will be low when inactive and high when active. Active Low- Pins will be high when inactive and low when active.
Timer
| Timer associated with PWM to drive the output. Warning - All PWM channels linked to the same timer will share the same period and prescaler settings.
Prescaler Divide
| Prescaler Divider value
Period Register
| PWM Period Register value
Dead Band
Rising Bits
| Number of bits assigned to the rising edge dead band counter. Auto populated based on selected target chip.
Falling Bits
| Number of bits assigned to the falling edge dead band counter. Auto populated based on selected target chip.
Rising Count
| Number of cycles to wait after a falling edge and before a rising edge.
Falling Count
| Number of cycles to wait after a rising edge and before a falling edge.
A Pin
| Output Pin A
B Pin
| Output Pin B
C Pin
| Output Pin C
D Pin
| Output Pin D
A Remap Pin
| Remap Pin A - Specifies the pin used for the A output. Only available on devices supporting remappable hardware pins.
B Remap Pin
| Remap Pin B - Specifies the pin used for the B output. Only available on devices supporting remappable hardware pins.
C Remap Pin
| Remap Pin C - Specifies the pin used for the C output. Only available on devices supporting remappable hardware pins.
D Remap Pin
| Remap Pin D - Specifies the pin used for the D output. Only available on devices supporting remappable hardware pins.
Calculations
Clock Speed
| Target Microcontroller Clock Speed.
Period (uS)
| Calculated length of PWM period in micro seconds.
Frequency (KHz)
| Calculated PWM output frequency in KHz.
Frequency (Hz)
| Calculated PWM output frequency in Hz.
