| Author | Matrix Ltd |
| Version | 1.1 |
| Category | Magnetic |
Hall Effect Digital component
Simple digital hall effect on off switch triggered by the proximity of another object.
Please click here to download the component source project: FC_Comp_Source_HallEffect_Digital.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_HallEffect_Digital.fcfx
Sample program using the EBM011 - Hall Effect sensor
Reads the sensor and displays output on LED D7.
 EBM011 Example
EBM011 Example
ReadState
|   | ReadState |
| Get the current collision state. The 'Polarity' property will affect whether a collision is represented by a high or low state. |
|  - BYTE | Return |
SetTarget
|   | SetTarget |
| Set the object that you want to test for collision with. If this is not called, or is called with handle = 0, collisions will be tested against every panel object that has 'Solid' status. NB) Specifying an object will save CPU power!! |
|  - HANDLE | Target |
| The object to test for collision with. |
|  - VOID | Return |
WaitUntilHigh
|   | WaitUntilHigh |
| Pause the program until the detector goes high.  'Polarity' will affect whether high value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!! |
|  - VOID | Return |
WaitUntilLow
|   | WaitUntilLow |
| Pause the program until the detector goes low.  'Polarity' will affect whether low value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!! |
|  - VOID | Return |
|   | Properties |
|   | Connections |
|   | Pin |
| The chip pin that will receive the switch status. |
|   | Polarity |
| Select the pin state that will indicate that an object has been detected. |
|   | Simulation |
|   | Magnet Object |
| Select an object from the panel to act as the magnet that triggers the reed switch. |
|   | Range |
| Distance within which the switch is activated. NB)  This is measured between the centre of the proximity switch and the centre of the target object. |
|   | Timer Interval (ms) |
| Time in milliseconds between testing for proximity. Small time = Greater CPU load Large time = More like to miss activation if it is very brief. |
