Component: LCD (Grove - I2C) (Alphanumeric)
Revision as of 13:11, 7 February 2023 by Wiki bot (talk | contribs)
Version 2.1
Category Alphanumeric
LCD (Grove - I2C) component
Standard alphanumeric LCD based on the Grove I2C LCD module with RGB backlight.
Please click here to download the component source project: FC_Comp_Source_LCD_Grove_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_Grove_I2C.fcfx
BacklightControl
BacklightControl
- BYTE Red
- BYTE Green
- BYTE Blue
Clear
Clear
ClearLine
ClearLine
- BYTE Line
Command
Command
- BYTE instruction
Cursor
Cursor
- BYTE x
- BYTE y
PrintAscii
PrintAscii
- BYTE character
PrintFloat
PrintFloat
- FLOAT Number
- BYTE DecimalPlaces
PrintFormattedNumber
- ULONG Number
- BOOL Format
0=Signed, 1=Unsigned
Allows you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT Number
PrintString
PrintString
- STRING Text
RAMWrite
RAMWrite
- BYTE Index
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
ScrollDisplay
ScrollDisplay
- BYTE position
- BYTE direction
SetI2CAddress
SetI2CAddress
Allows the I2C device address to be dynamically changed in software without having to re-compile. Can be called before the first Start macro or at any point after.
- BYTE Address
New I2C Device Address excluding R/W bit - Range 0 - 127
Start
Start
Startup routine required by the hardware device.
I2C Config
LCD Address
RGB Address
Alt RGB Address
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
LCD Configuration
Rows
Columns
Component Label
Component Label Scale
Text Colour
Colour of the font characters drawn on the display
Text Background
Display Background
Simulate Comms
Used to drive the comms durig simulation which can be used to: Data Recorder waveform generation Console Logging Data Injector to redirect the data e.g. to a SCADA slave connected to the physical hardware
API
