Component: Starburst Display 2D (Segment)
Revision as of 13:11, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.4
Category Segment
Starburst Display 2D component
Starburst 14 or 16 segment display modelled after a standard 14mm high unit. LED colour can be changed in properties.
Please click here to download the component source project: FC_Comp_Source_LED_Starburst_Single_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Starburst_Single_2dgi.fcfx
ClearSegments
Fc9-comp-macro.png ClearSegments
This funtion clears all the individual segments including the decimal point segment. In simulation this sets the colours to the default BGColor component variable.
ShowCharacter
Fc9-comp-macro.png ShowCharacter
Allows certain pre-programmed characters to be displayed. 0-9, A-Z, $, [, ], +, -, \, /, *, _, {, }, .
0-9 or A-Z
Fc9-u8-icon.png - BYTE DecimalPoint
0=Off, 1=On
ShowSegments
Fc9-comp-macro.png ShowSegments
Creates the supplied digit on the 7 segment display. Macro takes the digit to display and a boolean representing whether to display the decimal point segment or not.
Fc9-u8-icon.png - BYTE Segments0
Segment bits 0=Off 1=On : F/E/D2/D/C/B/A2/A
Fc9-u8-icon.png - BYTE Segments1
Segment bits 0=Off 1=On : M/L/K/J/I/H/G2/G1
Segment bits 0=Off 1=On : DecimalPoint
Fc9-type-16-icon.png Display Segments
Controls the starburst display type and number of segments available.
Fc9-type-16-icon.png Display Type
Set this property to match your hardware device. Common Anode: Common Pin High, Segment Pin Low = LED On Common Cathode: Common Pin Low, Segment Pin High = LED On
Fc9-type-16-icon.png Common Mode
Controls if the display will be multiplexed or always on. Multplexed uses the common pin to switch a individual display on or off allowing for multiple displays. Always on removes the common pin assuming you are only using a single starburst display.
Fc9-type-7-icon.png Show Seg Labels
Show the identifier lables of the segments overlayed over the component.
Fc9-type-5-icon.png Pin A
Pin connected to the 'A' segment of the display.
Fc9-type-5-icon.png Pin B
Pin connected to the 'B' segment of the display.
Fc9-type-5-icon.png Pin C
Pin connected to the 'C' segment of the display.
Fc9-type-5-icon.png Pin D
Pin connected to the 'D' segment of the display.
Fc9-type-5-icon.png Pin E
Pin connected to the 'E' segment of the display.
Fc9-type-5-icon.png Pin F
Pin connected to the 'F' segment of the display.
Fc9-type-5-icon.png Pin G1
Pin connected to the 'G1' segment of the display.
Fc9-type-5-icon.png Pin G2
Pin connected to the 'G2' segment of the display.
Fc9-type-5-icon.png Pin H
Pin connected to the 'H' segment of the display.
Fc9-type-5-icon.png Pin I
Pin connected to the 'I' segment of the display.
Fc9-type-5-icon.png Pin J
Pin connected to the 'J' segment of the display.
Fc9-type-5-icon.png Pin K
Pin connected to the 'K' segment of the display.
Fc9-type-5-icon.png Pin L
Pin connected to the 'L' segment of the display.
Fc9-type-5-icon.png Pin M
Pin connected to the 'M' segment of the display.
Fc9-type-5-icon.png Pin DP
Pin connected to the decimal point segment of the display.
Fc9-type-5-icon.png Common
Pin connection to the 'common' pin of the display - to allow enable/disable of the whole display.
Fc9-conn-icon.png Colors
Fc9-type-1-icon.png LED Color
Color when an LED is turned on. When turned off, will use a much darker shade of the same hue.
Fc9-type-1-icon.png Bezel Color
Color of the plastic package housing the LEDs
Fc9-type-1-icon.png Label Color
Color of the optional segment name labels.
