Component: LED Template (LED)
Revision as of 13:11, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.3
Category LED
LED Template component
Base for creating LEDs and other on/off visual indicators. Choose a 'Target Object' that will change colour when the pin changes; if multiple objects must change color, group them, and target the group. When 'Auto off color" is selected, changing the 'on color' will automatically choose an off color by reducing the on-color intensity.
Please click here to download the component source project: FC_Comp_Source_LED_Base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Base.fcfx
TurnOff
TurnOff
Turn the LED off. Active high - The pin is configured to output low. Active low - The pin is configured to output high.
TurnOn
TurnOn
Turn the LED on. Active high - The pin is configured to output high. Active low - The pin is configured to output low.
Pin
Chip pin to connect the LED to.
Polarity
Active High: Pin true -> On color, Pin false -> Off color Active Low: Pin true -> Off color, Pin false -> On color
Target Object
Set a target object to be the illuminating part of the LED. To change the colour of multiple objects, group them first, then target the group.
On Color
The color of the LED when it is turned on.
Off Color
The color of the LED when it is turned off.
Auto Off Color
When this is selected, the off color is automatically set to a darker version of the on color.
