Component: RGB LED LP5030 LP5036 (LEDs)
Revision as of 13:11, 7 February 2023 by Wiki bot (talk | contribs)
Category LEDs
RGB LED LP5030 LP5036 component
An I2C Based RGB LED driver with 30 or 36 individual constant-current sinks. Used to drive 10 or 12 RGB LEDs with a wide range of applications.
Please click here to download the component source project: FC_Comp_Source_LP5036_RGB_LED.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LP5036_RGB_LED.fcfx
GetBrightness
GetBrightness
Gets the brightness of a single LED.
- BYTE Address
Range: 0-11
- BYTE RGB
Byte array containing at least 3 bytes to store Red, Green and Blue
GetDiscreteRGB
GetDiscreteRGB
Gets the RGB format colour of a single LED.
- BYTE Address
Range: 0-11
- BYTE ColourIndex
GetRGB
GetRGB
Gets the RGB colour of a single LED. Array variables only. For individual variables, use GetDiscreteRGB
- BYTE Address
Range: 0-11
- BYTE RGB
Starts up the I2C comms ready for communicating with the LP503x module. Must be called before any of the other component macros are called.
ReadReg
ReadReg
Reads the data from one or more sequential registers
- BYTE Address
- BYTE Data
- BYTE Count
SetBrightness
SetBrightness
Allows the brightness of a single LED to be specified as a byte from 0 to 255. Default on reset is 255.
- BYTE Address
Range: 0-11
- BYTE Brightness
Brightness value: Range 0-255
SetDiscreteRGB
SetDiscreteRGB
Allows the colour of a single LED to be specified in RGB format
- BYTE Address
Range: 0-11
- BYTE Red
- BYTE Green
- BYTE Blue
SetRGB
SetRGB
Allows the colour of a single LED to be specified in RGB. Array variables only. For individual variables and literal values, use SetDiscreteRGB
- BYTE Address
Range: 0-11
- BYTE RGB
Byte array containing at least 3 bytes to set Red, Green and Blue
SetUnitAddress
SetUnitAddress
Allows the component to taklk to more then one IC or broadcast to all connected ICs.
- BYTE Address
Range: 0-3 = Individual / 4 = Broadcast
WriteReg
WriteReg
Writes data to one or more sequential registers
- BYTE Address
- BYTE Data
- BYTE Count
Driver
Driver IC
Address Pins
Channel selection
Baud Select
Baud rate to be used
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
