| Author
| Version
1.0
| Category
Electrical
LTSR Current Transducer component
LTSR rage of +/- 6, 15 & 25A current Tranducers
Please click here to download the component source project: FC_Comp_Source_LTSR_Current_Transducer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LTSR_Current_Transducer.fcfx
Current
Current
- FLOAT
Device
VDD
| Analogue Input Channel - Which pin is the analogue input connected to?
VRef option
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
VRef voltage
| Used by the GetVoltage or GetString component macros to take an ADC reading and convert it into a Voltage. +VRef voltage x 10mV Default 500 = 5.0V
Conversion speed
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock.
Acquisition cycles
| Number of micro seconds to wait for the ADC input to charge before starting the analogue sample.
