Component: Load Cell (HX711) (Force)
Revision as of 13:11, 7 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Force
Load Cell (HX711) component
The HX711 load cell amplifier is used to get measurable data out from a load cell or strain gauge.
Please click here to download the component source project: FC_Comp_Source_Load_Cell_HX711.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Load_Cell_HX711.fcfx
A simple example showing how to get a meaningful reading out of the HX711 IC connected to a load cell sensor. Zeros/Tares the reading when the switch is pressed.
FC6 Icon.png HX711 Example
The scale factor was determined by performing calibration with a unity scale of 1.0 and fixed weight weights. A table of weight vs reading was constructed to provide the correct scale factor.
Here is a guide to calibrate your sensor
When 0g was present on the load cell we zero the output.
When 10g was present on the load cell we get a reading of approx 2170.
2170 / 10g = 217 per g.
When 20g was present on the load cell we get a reading of approx 4340.
4340 / 20g = 217 per g.
1 / 217 = Scale Factor of 0.004608
The readings may not be 100% linear so it's best to take several samples based on different weights across the range you want to be able to measure and from this you can work out a close fitting average.
Fc9-comp-macro.png Initialise
Sets up the I/O ready for communications with the HX711 IC and performs an initial sample to set the channel and gain. Must be called before calling other HX711 component macros.
RawSample
Fc9-comp-macro.png RawSample
Allows the HX711 to be directly read returning the raw unscaled 24-bit reading. Reading is relative to the last defined Zero point. If a timeout occurs and the HX711 is not ready then we return the last valid reading.
ScaledSample
Fc9-comp-macro.png ScaledSample
Takes a raw sample and then applies the scaling factor to return a real world value.
SetChannelAndGain
Fc9-comp-macro.png SetChannelAndGain
Allows the preselected input channel and gain to be overridden.
Fc9-bool-icon.png - BOOL Channel
Range: 0-1 / 0=A 1=B
Fc9-u8-icon.png - BYTE Gain
Channel A can be 128 or 64, Channel B can be 32
SetSampleCount
Fc9-comp-macro.png SetSampleCount
Specifies the number of samples to perform when taking a reading. The more samples the more filtered the signal will become from high frequency noise.
Fc9-u8-icon.png - BYTE NumSamples
Default 1. Range 1-20
Fc9-u16-icon.png - UINT Delay
Time to wait between samples in milliseconds.
SetScaling
Fc9-comp-macro.png SetScaling
Sets the scaler for the samples to provide a meanningful value. Default scaler is set to 1.0
Fc9-f32-icon.png - FLOAT Scaler
Unity Scale = 1.0
Zero
Fc9-comp-macro.png Zero
Zeros the reading at the current sample
Fc9-type-16-icon.png Input Channel
Selects which channel to sample A or B. Gain settings are channel specific. A Gain can be 128x or 64x B Gain is fixed at 32x
Fc9-type-16-icon.png Input Gain
Fc9-type-5-icon.png Data
Data pin - connected to HX711 Data Out pin.
Fc9-type-5-icon.png Clock
Clock pin - connected to HX711 SCK pin.
Fc9-type-21-icon.png Clock Transition Delay
Number of microseconds to wait after each clock edge. Max theoretical: 10Hz Mode = 1uS / 80 Hz Mode = 4uS
Fc9-type-7-icon.png Use Median Filter
