Component: OBD2 ECU (Server) (Misc)
Jump to navigationJump to search| Author | |
| Category | Misc |
- 1 OBD2 ECU (Server) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 DTC_Add
- 5.2 DTC_Clear
- 5.3 DTC_Count
- 5.4 DTC_Get
- 5.5 FlushBuffer
- 5.6 GetByte
- 5.7 GetNumberBytes
- 5.8 Initialise
- 5.9 Process
- 5.10 Set_ECU_Name
- 5.11 Set_Engine_Coolant_Temperature
- 5.12 Set_Engine_Load
- 5.13 Set_Engine_Speed
- 5.14 Set_MAF_Rate
- 5.15 Set_Throttle_Position
- 5.16 Set_VIN
- 5.17 Set_Vehicle_Speed
- 6 Property reference
Implements an ECU side OBD-II server
Please click here to download the component source project: FC_Comp_Source_OBD2_ECU.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_OBD2_ECU.fcfx
DTC_Add
DTC_Clear
| DTC_Clear | |
| Clears the DTC store | |
DTC_Count
| DTC_Count | |
| Returns the number of stored DTCs | |
DTC_Get
| DTC_Get | |
| Get the DTC from the store at Index | |
| Index | |
FlushBuffer
| FlushBuffer | |
| Clears the contents of the buffer and re-initialises the index locations. | |
GetByte
| GetByte | |
| Reads the next available byte from the circular buffer, Returns 255 if the buffer is empty. | |
GetNumberBytes
| GetNumberBytes | |
| Returns the number of valid data bytes currently inside the buffer. | |
| Initialise the CAN network | |
Process
| Process | |
| Does the message processing. Call this often. | |
| TimeElapsed | |
| Time elapsed since last call, in mS. Can be zero for frequent calling. | |
Set_ECU_Name
| Set_ECU_Name | |
| Set the ECU Name | |
| Name | |
| Set_Engine_Coolant_Temperature | |
| -40 to 215 (deg C) | |
| Value | |
| Value range -40 to 215 deg C | |
Set_Engine_Load
| Set_Engine_Load | |
| 0 to 100 (%) | |
| Value | |
| Speed in RPM | |
Set_Engine_Speed
| Set_Engine_Speed | |
| 0 to 16,383.75 (rpm) | |
| Value | |
| Speed in RPM | |
Set_MAF_Rate
| Set_MAF_Rate | |
| 0 to 655.35 grams/sec | |
| Value | |
| MAF air flow rate in grams/sec | |
| Set_Throttle_Position | |
| 0 - 100 (%) | |
| Value | |
| Position value as a percentage (0 - 100%) | |
Set_VIN
| Set_VIN | |
| Set the 17 character VIN | |
| VIN | |
Set_Vehicle_Speed
| Set_Vehicle_Speed | |
| 0 - 255 (km/h) | |
| Value | |
| Speed in RPM | |
