Component: Potentiometer (Analog Input)
Version | 1.0 |
Category | Analog Input |
Potentiometer component
Please click here to download the component source project: FC_Comp_Source_Potentiometer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Potentiometer.fcfx
Ev_Start
Ev_Start | |
Broadcast to all components that simulation is starting | |
- ULONG | Return |
GetValue
GetValue | |
Get the Float value, between lower and upper bounds. Used on App Developer | |
- FLOAT | Return |
ReadAsByte
ReadAsByte | |
Read the ADC as a byte | |
- BYTE | Return |
ReadAsFloat
ReadAsFloat | |
Reads the ADC as a direct voltage | |
- FLOAT | Return |
ReadAsInt
ReadAsInt | |
Read the ADC at full bit depth | |
- INT | Return |
ReadAsVoltage
ReadAsVoltage | |
- FLOAT | Return |
SetValue
SetValue | |
Sets the Float value, between lower and upper bounds. Used on App Developer | |
- FLOAT | Value |
- VOID | Return |
