Component: Air Quality (BME680) (BME680) (Environmental)
Revision as of 13:12, 7 February 2023 by Wiki bot (talk | contribs)
Category Environmental
Air Quality (BME680) component
A low power sensor capable of measuring air quality, pressure, temperature and humidiy. Connected to microcontroller using either I2C or SPI communications bus.
Please click here to download the component source project: FC_Comp_Source_Pressure_and_Air_BME680.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Pressure_and_Air_BME680.fcfx
Fc9-comp-macro.png Initialise
Fc9-type-16-icon.png Comms Type
Allows the communications to be simulated to allow for data to be sent via injector components,
Fc9-conn-icon.png I2C Comms
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-16-icon.png SDO Address Pin
The SDO pin specifies the least significant bit of the device address.
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Sensor Configuration
Fc9-type-16-icon.png Humidity Oversampling
Controls the humidity oversampling setting
Fc9-type-16-icon.png Temperature Oversampling
Controls the temperature oversampling setting
Fc9-type-16-icon.png Pressure Oversampling
Controls the pressure oversampling setting
Fc9-type-16-icon.png IIR Filter
Controls the filter coefficient used on the temperature and pressure data
Fc9-type-16-icon.png Gas Wait Time
Gas sensor wait time multiplication factor
