Component: USB Slave Free (Misc)
Revision as of 13:13, 7 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.1
Category Misc
USB Slave Free component
Component to create and communicate using a generic USB communications profile. Has the ability to allow the device to be a slave to the PC. Compatible with simulation and USB enabled microcontroller devices (PIC/dsPIC).
Please click here to download the component source project: FC_Comp_Source_USBSlave_Free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_USBSlave_Free.fcfx
The PIC based ECIOs or MIAC are good targets for USB as they do not have any additional configuration setting that need to be setup to allow the firmware to run correctly. For other targets you will have to setup the configuration correctly for your hardware to allow the USB to run correctly.
Basic Embedded Example
Here is an example file which waits for incoming data and then when valid data is received it displays this as a binary value onto the PortB pins before echoing back the data. FC6 Icon.png USB Slave Simple Receive
USB Drivers
The example requires a device driver to function correctly. The driver can be generated by selecting the USB Slave component on the System panel, Looking down the list of properties in the properties window, selecting the Generate Driver property and switching the setting to Yes. This will place the driver .inf file into the same directory as the Flowcode fcfx project file is located.
Here is a signed version of the USB Slave device driver using the default VID/PID properties. The .inf driver file generated by Flowcode also requires some associated files which are not auto generated, these files can also be downloaded here.
ZIP Icon.png USB Slave Driver
The final driver files can be assembled by extracting the contents of the zip archive into a folder on your computer and adding the .inf file created by your Flowcode project. Running the correct executable for your PC type should then auto install the driver for you.
When the driver is installed correctly you will get your device showing up in the Windows device manager like this.
Basic Simulations Example
Here is an example file which is designed to run in simulation to communicate with the connected embedded device. The instance property will have to match the USB instance for the embedded device to allow the communications to work correctly. FC6 Icon.png USB Slave Simulation The USB Slave instance is selected by selecting the USB slave component on the panel and setting the instance property.
When editing the USB Slave examples the slave service macro needs to match the setting in the USB Slave properties as shown below.
Slave Macro Setup
Slave Properties
Example console showing the data passed between the simulation and the embedded hardware.
The MIAC USB Slave and ECIO USB Slave Components are written based on the USB Slave component so these give a good example of what is possible using the component.
CheckRx
Fc9-comp-macro.png CheckRx
Called to check if there is any incoming data waiting to be received. Returns the number of incoming data bytes. Only needed when not running the slave service.
GetByte
Fc9-comp-macro.png GetByte
Retreives the byte at location Idx from the incoming data buffer.
Fc9-u8-icon.png - BYTE Idx
Specifies the location in the incoming buffer
GetString
Fc9-comp-macro.png GetString
Retreives a string of data from the incoming data buffer starting from location 0 and incrementing up to the NumBytes parameter.
Fc9-u8-icon.png - BYTE NumBytes
Specifies the maximum number of bytes to try and read.
Fc9-comp-macro.png Initialise
Starts up the USB communications and attempts to enumerate. Returns 0 for a successful startup or 255 for a enumeration timeout.
RunSlaveService
Fc9-comp-macro.png RunSlaveService
Stalls the microcontroller and waits for an incoming message from the USB, when a message is received the macro defined in the USB Slave properties is automatically run. While the macro is running you can choose to send data back to the PC if you wish.
SendByte
Fc9-comp-macro.png SendByte
Adds the byte onto the end of the outgoing data buffer.
Fc9-u8-icon.png - BYTE Data
Data byte to transmit to the host
SendByteArray
Fc9-comp-macro.png SendByteArray
Adds an array of bytes onto the end of the outgoing data buffer.
[[File:]] - Data
Data Bytes To Send
Fc9-u8-icon.png - BYTE Length
Max number of bytes to try and add to the outgoing buffer.
SendString
Fc9-comp-macro.png SendString
Adds a string of bytes onto the end of the outgoing data buffer.
Data String To Send
StopSlaveService
Fc9-comp-macro.png StopSlaveService
Allows the microcontroller to leave the stalled slave mode and resume its normal independant functionality. Must be called from within the slave service routine to work correctly.
Fc9-conn-icon.png USB Properties
Fc9-type-14-icon.png Vendor ID
USB VID
Fc9-type-14-icon.png Product ID
USB PID
Fc9-type-10-icon.png Device Name
USB Device Name
Fc9-type-10-icon.png Manufacturer
USB Manufacturer
Fc9-type-14-icon.png Major Version
USB Major Version Number
Fc9-type-14-icon.png Minor Version
USB Minor Version Number
Fc9-type-7-icon.png Enumeration Timeout
Specifies if the enumeration (Initialise function) can timeout if taking too long.
Fc9-type-16-icon.png Country Code
Country code used by some regional based USB devices
Fc9-type-14-icon.png Maximum Current (mA)
Maximum amount of current the USB host will provide before shutting down the USB channel.
Fc9-conn-icon.png Slave Macro Properties
Fc9-type-10-icon.png Slave Macro
Flowcode macro to call while the slave service is enabled
Fc9-type-16-icon.png Macro Parameters
Defines the parameters for the slave service macro allowing data from the host to be automatically passed into the macro.
Fc9-conn-icon.png USB Driver
Fc9-type-10-icon.png Driver Directory
Directory to save the generated device driver .inf file
Fc9-type-10-icon.png Driver Filename
Filename assigned to the USB device driver .inf file when generated.
Fc9-type-7-icon.png Generate Driver
Generates a driver file when set to Yes, Automatically jumps back to No when complete.
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Instance
Hardware instance to communicate with any connected USB slave devices.
Fc9-type-21-icon.png Timeout (ms)
Simulation host to slave communications timeout in milliseconds
Fc9-type-10-icon.png Label
Text displayed on the I/O flasher comms component.
