Component: Webserver (EB023 v1) (E-blocks 1)
Revision as of 13:13, 7 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category E-blocks 1
Webserver component
Webserver component designed to work with the NM7010A module from Wiznet, as used in the version 1 EB023 E-block. Provides a very simple interface to allow webpages to be hosted from hardware or simulation.
Please click here to download the component source project: FC_Comp_Source_WebServer_EB023-00-1_EB.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WebServer_EB023-00-1_EB.fcfx
CheckSocketActivity
CheckSocketActivity
Checks for activity on the server socket and serves out the webpages to any requesting parties.
CreateServerSocket
CreateServerSocket
Creates a listening socket on the selected channel and port ready to accept incoming web page requests.
- BYTE Channel
- BYTE Port_Hi
- BYTE Port_Lo
GetInValue
GetInValue
- BYTE index
- STRING Return
IncRxPtr
IncRxPtr
- BYTE Channel
Send_Embedded_HTML_Page1
Send_Embedded_HTML_Page2
Send_Embedded_HTML_Page3
Send_Embedded_HTML_Page4
SetOutValue
SetOutValue
- BYTE index
- STRING value
Max Channels
Max number of concurrent channels allowed
I2C Address
I2C address of the module - bit 0
HTML Source
HTML Source
Sets the method for streaming data, we can either host it loacally using a property or refer to external files.
Max Pages
Maximum number of pages we can serve using the embedded page type webserver.
Name Page 1
Name of HTML page 1 - index.htm is the default page that will be presented.
HTML Page 1
Embedded HTML code used for page 1
Name Page 2
Name of HTML page 2
HTML Page 2
Embedded HTML code used for page 2
Name Page 3
Name of HTML page 3
HTML Page 3
Embedded HTML code used for page 3
Name Page 4
Name of HTML page 4
HTML Page 4
Embedded HTML code used for page 4
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Int Pin
Interrupt pin connection on Wiznet module
Gateway IP
Gateway0
IP address of the gateway to the internet if applicable.
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet mask of the server - usually 255.255.255.0
Subnet1
Subnet2
Subnet3
IP Address
IP0
IP address of the server - usually 192.168.0.x or 192.168.1.x
IP1
IP2
IP3
MAC Address
MAC0
MAC address of the server
MAC1
MAC2
MAC3
MAC4
MAC5
Substitutions
Outgoing
Count
Length 0
Length 1
Length 2
Incoming
Count
Length 0
