| Author | Matrix Ltd |
| Category | Third Party |
FTDI (FTD2XX) component
Simulation only interface to allow communications with a FTDI USB 232 IC connected to the system. For more details refer to the D2XX_Programmers_Guide from FTDI.
Please click here to download the component source project: FC_Comp_Source_ftd2xx_232.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_ftd2xx_232.fcsx
FT_Close
|   | FT_Close |
| Close an open device. |
|  - LONG | Handle |
| Handle of the device. |
|  - BYTE | Return |
FT_ClrDtr
|   | FT_ClrDtr |
| This function clears the Data Terminal Ready (DTR) control signal. |
|  - LONG | Handle |
|  - BYTE | Return |
FT_ClrRts
|   | FT_ClrRts |
| This function clears the Request To Send (RTS) control signal. |
|  - LONG | Handle |
|  - VOID | Return |
FT_CreateDeviceInfoList
|   | FT_CreateDeviceInfoList |
| This function builds a device information list and returns the number of D2XX devices connected to the system. The list contains information about both unopen and open devices. |
|  - LONG | DevCount |
| Unsigned long array used to store the number of devices connected |
|  - BYTE | Return |
FT_GetDeviceInfoDetail
|   | FT_GetDeviceInfoDetail |
| This function returns an entry from the device information list. |
|  - ULONG | Index |
| Index of the entry in the device info list. |
|  - ULONG | Flags |
| Pointer to unsigned long to store the flag value. |
|  - ULONG | Type |
| Pointer to unsigned long to store device type. |
|  - ULONG | ID |
| Pointer to unsigned long to store device ID. |
|  - ULONG | LocID |
| Pointer to unsigned long to store the device location ID. |
|  - BYTE | SerNum |
| Pointer to buffer to store device serial number as a null terminated string |
|  - BYTE | Descript |
| Pointer to buffer to store device description as a null-terminated string |
|  - LONG | TempHandle |
| Pointer to a variable of type FT_HANDLE where the handle will be stored |
|  - BYTE | Return |
FT_GetModemStatus
|   | FT_GetModemStatus |
| Gets the modem status and line status from the device. |
|  - LONG | Handle |
|  - LONG | ModemStatus |
| Pointer to a variable of type DWORD which receives the modem status and line status from the device. |
|  - BYTE | Return |
FT_GetQueueStatus
|   | FT_GetQueueStatus |
| Gets the number of bytes in the receive queue. |
|  - LONG | Handle |
|  - LONG | RxQueueLength |
| Pointer to a variable of type DWORD which receives the number of bytes in the receive queue. |
|  - BYTE | Return |
FT_GetStatus
|   | FT_GetStatus |
| Gets the device status including number of characters in the receive queue, number of characters in the transmit queue, and the current event status. |
|  - LONG | Handle |
| Pointer to a variable of type DWORD which receives the number of characters in the receive queue. |
|  - LONG | TxQueueLength |
| Pointer to a variable of type DWORD which receives the number of characters in the transmit queue. |
|  - LONG | EventStatus |
| Pointer to a variable of type DWORD which receives the current state of the event status. |
|  - BYTE | Return |
FT_Open
|   | FT_Open |
| Open the device and return a handle which will be used for subsequent accesses. |
|  - INT | Device |
| Index of the device to open.  Indices are 0 based. |
|  - LONG | ft_Handle |
| Pointer to a variable of type FT_HANDLE where the handle will be stored.  This handle must be used to access the device. |
|  - BYTE | Return |
FT_Purge
|   | FT_Purge |
| This function purges receive and transmit buffers in the device. |
|  - LONG | Handle |
|  - LONG | Mask |
| Used to determine which buffer to purge, 1=Rx / 2=Tx / 3=Both |
|  - BYTE | Return |
FT_Read
|   | FT_Read |
| Read data from the device. |
|  - LONG | Handle |
|  - BYTE | Buffer |
| Pointer to the buffer that receives the data from the device. |
|  - ULONG | Bytes |
| Number of bytes to be read from the device. |
|  - ULONG | Count |
| Pointer to a variable of type DWORD which receives the number of bytes read from the device. |
|  - BYTE | Return |
FT_ResetDevice
|   | FT_ResetDevice |
| This function sends a reset command to the device. |
|  - LONG | Handle |
|  - BYTE | Return |
FT_SetBaudRate
|   | FT_SetBaudRate |
| This function sets the baud rate for the device. |
|  - LONG | Handle |
|  - ULONG | BaudRate |
| Baud rate. |
|  - BYTE | Return |
FT_SetBitMode
|   | FT_SetBitMode |
| Enables different chip modes. |
|  - LONG | Handle |
|  - BYTE | Mask |
| Required value for bit mode mask. This sets up which bits are  inputs and outputs.  A bit value of 0 sets the corresponding pin to  an input, a bit value of 1 sets the corresponding pin to an output. |
|  - BYTE | Mode |
| 0=Reset / 1=AsyncBB / 2=MPSSE / 4=SyncBB / 8=MCUHost / 16=FastOpto / 32=CBUS / 64=SyncFIFO |
|  - BYTE | Return |
FT_SetBreakOff
|   | FT_SetBreakOff |
| Resets the BREAK condition for the device. |
|  - LONG | Handle |
|  - BYTE | Return |
FT_SetBreakOn
|   | FT_SetBreakOn |
| Sets the BREAK condition for the device. |
|  - LONG | Handle |
|  - BYTE | Return |
FT_SetChars
|   | FT_SetChars |
| This function sets the special characters for the device. |
|  - LONG | Handle |
|  - BYTE | EventCh |
| Event character. |
|  - BYTE | EventChEn |
| 0 if event character disabled, non-zero otherwise. |
|  - BYTE | ErrorCh |
| Error character. |
|  - BYTE | ErrorChEn |
| 0 if error character disabled, non-zero otherwise. |
|  - BYTE | Return |
FT_SetDataCharacteristics
|   | FT_SetDataCharacteristics |
| This function sets the data characteristics for the device. |
|  - LONG | Handle |
|  - BYTE | WordLength |
| Number of bits per word - Must be 7 or 8 |
|  - BYTE | StopBits |
| Number of stop bits - Must be 1 or 2 |
|  - BYTE | Parity |
| Parity 0=None / 1=Odd / 2=Even / 3=Mark / 4=Space |
|  - BYTE | Return |
FT_SetDivisor
|   | FT_SetDivisor |
| This function sets the baud rate for the device. It is used to set non-standard baud rates. |
|  - LONG | Handle |
|  - UINT | Divisor |
| Divisor. |
|  - BYTE | Return |
FT_SetDtr
|   | FT_SetDtr |
| This function sets the Data Terminal Ready (DTR) control signal. |
|  - LONG | Handle |
|  - BYTE | Return |
FT_SetFlowControl
|   | FT_SetFlowControl |
| This function sets the flow control for the device. |
|  - LONG | Handle |
|  - UINT | FlowControl |
| Flow setting 0=None, 0x0100=RTS/CTS, 0x0200=DTR/DSR, 0x0400=XON/XOFF |
|  - BYTE | Xon |
| Character used to signal Xon. Only used if flow control is Xon/Xoff |
|  - BYTE | Xoff |
| Character used to signal Xoff. Only used if flow control is Xon/Xoff |
|  - BYTE | Return |
FT_SetRts
|   | FT_SetRts |
| This function sets the Request To Send (RTS) control signal. |
|  - LONG | Handle |
|  - BYTE | Return |
FT_SetTimeouts
|   | FT_SetTimeouts |
| This function sets the read and write timeouts for the device. |
|  - LONG | Handle |
|  - LONG | ReadTimeout |
| Read timeout in milliseconds. |
|  - LONG | WriteTimeout |
| Write timeout in milliseconds. |
|  - BYTE | Return |
FT_Write
|   | FT_Write |
| Write data to the device. |
|  - LONG | Handle |
|  - BYTE | Buffer |
| Pointer to the buffer that contains the data to be written to the device. |
|  - ULONG | Bytes |
| Number of bytes to write to the device. |
|  - ULONG | Count |
| Pointer to a variable of type DWORD which receives the number of bytes written to the device. |
|  - BYTE | Return |
ScanFor232
|   | ScanFor232 |
| Scans for a FTDI D2XX device, returnes true if at least one device was found. |
|  - BOOL | Return |
|   | Properties |
|   | Label |
| A text label for the component's panel component. |
