Component: Switch (Toggle, Panel) ()
Author | Matrix Ltd |
Version | 1.1 |
Category |
Switch (Toggle, Panel) component
Miniature toggle switch with metal tamg - solder lugs and nut for panel mounting.
Please click here to download the component source project: FC_Comp_Source_sw_toggle_panel.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_sw_toggle_panel.fcfx
Switch
(5V / 11K) * 10K = 4.54545V
